ᐅ How can I install Ikea Metod kitchen units in a space-saving way?
Created on: 16 Jun 2023 08:13
kinsolvi
Good morning everyone, I am planning a new kitchen using Ikea Metod and have some uncertainties about how to design the kitchen layout in the most space-saving way. I’m not only concerned about the overall width or length but also about the optimal arrangement of cabinets and work surfaces to make the best use of the available space.
Specifically, I am interested in:
- Which modules or combinations are especially efficient for small or narrow rooms?
- Are there smart solutions for storage below or above the work surface to keep the kitchen compact?
- What options are available for frequently used elements like the sink and stove, without taking up too much room?
I have done some research, but many tips are quite general. Who has experience with Metod and can offer specific recommendations, including advice on common installation methods or replacing baseboards/ skirting boards that affect usable space? Thanks in advance!
joro10
16 Jun 2023 11:42
If space is your top priority: 20cm (8 inches) drawers and pull-outs are great for spices or small kitchen tools, allowing you to make good use of narrow areas.
Wall cabinets can be used flexibly, for example with shelves instead of doors, which visually saves space.
Always install the sink near the water supply to avoid additional costs.
TARAON
16 Jun 2023 12:11
Hey, very interesting topic! A small tip from me: try using a corner solution with a pull-out pantry cabinet – the roll-front-style drawers are extremely practical and make such efficient use of corners that not a single centimeter (inch) is wasted.
kulau schrieb:
For corner cabinets, it’s better to use corner carousels or pull-out pantry cabinets, as they create storage space that is otherwise hard to access.
It also looks nice visually and makes cooking easier – I have similarly expanded a small kitchen in a practical way. Good luck!
PeoDaniel
16 Jun 2023 12:57
From my experience with Metod kitchens: Make sure to carefully align the modules during installation so the doors close properly later. Especially with slightly uneven floors, it helps to adjust the feet precisely.
Storage space increases significantly if you choose drawers instead of doors – you can often see the contents better, and everything is easily accessible.
Using flap cabinets above the work surface can create extra storage space without overcrowding the room.
kinsolvi
16 Jun 2023 14:20
Great, thanks for these clear pointers! I will definitely consider the corner cabinet solution.
What about the height? Is it worth building the kitchen units all the way up to the ceiling to maximize storage space? Does this offer practical benefits in everyday use, or is it mainly something for experts?
Also, I would like to know if anyone has experience with countertop depths in very small kitchens. I had been thinking about 60cm (24 inches), but would 50cm (20 inches) be a reasonable compromise?
angel
16 Jun 2023 15:10
kinsolvi schrieb:
How about the height? Is it worth building the kitchen cabinets all the way up to the ceiling to maximize storage space?
That definitely provides more storage space in small kitchens, but you should make sure the upper cabinets aren’t placed too high, as cleaning becomes difficult and reaching them is challenging. A common compromise is to install the upper cabinets about 20-30 cm (8-12 inches) below the ceiling and use the space above with closed boxes or narrow shelves.
kinsolvi schrieb:
Also, I’d like to know if anyone has experience with countertop depth in very small kitchens. I was thinking about 60 cm, but would 50 cm maybe be a reasonable compromise?
A 50 cm (20 inch) countertop depth is doable, but you should choose appliances and the sink accordingly. It’s not a standard size, so make sure your stove and sink models are compatible—some are not suitable for this depth.
Also important: plan enough depth for safe and comfortable work, at least 45-50 cm (18-20 inches) is the minimum. It’s also crucial to have enough clearance from the wall cabinets to avoid bumping your head.
Nabla64
16 Jun 2023 16:03
In addition to the previous points:
A continuous countertop with a depth of 60 cm (24 inches) is ideal because it works well with standard sinks and cooktops.
If space is tight, 50 cm (20 inches) can work, but you will lose some comfort when using large cutting boards or baking trays.
Regarding height: with Metod, you can combine wall cabinets of different heights. For example, corner units can be taller at the top and lower in the middle; this not only looks more relaxed visually but also offers greater flexibility.
Maximizing storage up to the ceiling is a good idea if you want more space, but keep in mind that the upper area is rarely used. Good planning with a step stool and a well-thought-out organization system is advisable.
I also recommend incorporating lighting or indirect lighting in the wall cabinet areas; this visually saves depth.
