ᐅ How can I install IKEA Metod kitchen cabinets in a limited space?
Created on: 17 Sep 2021 19:42
lanureo
lanureo
17 Sep 2021 19:42
I am currently planning my new kitchen with IKEA Metod cabinets and facing a challenge: the room where the kitchen will be installed is quite small, with limited space for units. The exact room layout allows only limited width and some narrow spots.
My question is: How do you build IKEA Metod kitchen cabinets in the most space-efficient way when space is really tight? What strategies have you used to design a functional and practical kitchen despite limited dimensions?
I am especially interested in:
- Tips for selecting and combining base cabinets and wall cabinets
- Recommendations on corner solutions or special modules
- Advice on how to best plan work surfaces when space is limited
- Experiences with installation in tight conditions, especially handling measurements and adjustments
It would be very helpful if you could share your experiences and solutions that I can apply to my own planning. Thanks in advance!
Jaime
18 Sep 2021 07:53
lanureo schrieb:
My question is: How can IKEA Metod kitchen cabinets be installed in the most space-efficient way when available space is really limited?
That is a very relevant question, especially for small rooms where a good design concept is crucial. In general, I recommend focusing on making the best use of vertical spaces. IKEA Metod offers various cabinets in different heights, and tall cabinets are often more practical than wide base cabinets when the floor area is limited.
- Corner solutions such as carousel units or pull-out drawers help make otherwise hard-to-reach corner areas truly usable.
- Work surfaces can be optimized with pull-out cutting boards—this temporarily adds more surface area without sacrificing fixed countertop space.
When measuring, it is essential to be very precise and to account for tolerances. Especially in tight spaces, I recommend loosely assembling the cabinets before final installation to identify and adjust for any irregularities in wall straightness or floor level.
From my experience: With careful planning and the use of modular elements, even small kitchens can be functional and visually appealing.
lomin
18 Sep 2021 14:35
Jaime schrieb:
Corner solutions such as carousel units or pull-outs help to make the usually hard-to-reach edge space truly usable.
I can only confirm that! I had a rather small kitchen and initially thought there wouldn’t be much space for practical work surfaces. But corner solutions really helped a lot because you don’t “lose” so much space in the corners anymore.
Jaime schrieb:
Work surfaces can be optimized with pull-out chopping boards – this way you temporarily gain more surface area without sacrificing fixed countertop space.
At first, I was a bit concerned whether the structure would still be stable, but in everyday use you hardly notice any difference. I think it’s important to be brave and try assembling the modules differently in the details.
Besides, I would recommend planning the loading of the base cabinets really smartly: instead of just shoving everything in, it’s better to create dedicated compartments for frequently used kitchen utensils, which saves you movements around the kitchen.
I also exchanged ideas with IKEA kitchen planners for my small kitchen – especially when space is limited, it’s worth doing this to avoid mistakes.
Guyju
19 Sep 2021 09:24
To add to the discussion, I’d like to share my experience and a brief step-by-step guide on how to optimally design and install IKEA Metod kitchens in limited space:
1. Measure the space precisely: Not only width and length but also wall straightness, angle deviations, and floor height. Record wall dimensions accurately in millimeters.
2. Use planning software: IKEA offers a kitchen planner tool that allows you to try different module options. Make sure to consider room conditions carefully, including doors and windows.
3. Maximize horizontal and vertical levels: Use tall cabinets along one wall and combine them with narrow upper cabinets to create as much storage as possible without blocking walking paths.
4. Prioritize corner solutions: As mentioned in previous posts, definitely use flexible corner cabinets. Carousel, Le Mans, or pull-out systems provide excellent accessibility in corners.
5. Adjust assembly on site: Especially with Metod, it’s important to partially assemble and align the furniture first before fully screwing everything together. Use brackets for adjustment to compensate for uneven walls.
6. Cleverly supplement work surfaces: Where fixed countertops are limited, extendable cutting boards or countertop extensions offer practical flexibility.
7. Plan drawers and internal pull-outs carefully: To maximize storage space, it’s better to work with internal pull-outs that can be customized individually.
Typical mistakes during installation include measuring too inaccurately and screwing too quickly without first testing the fit in the room. Focus on a calm, methodical assembly process.
I hope this helps with planning and assembling your Metod kitchen.
