ᐅ How do I install Ikea Metod kitchen cabinets for accessible kitchens?
Created on: 14 Jul 2021 09:23
melvinkiHello everyone,
I am currently planning to remodel my kitchen using METOD cabinets from IKEA, aiming to make it as barrier-free as possible. Besides the standard installation, I am especially interested in what adjustments should be considered during the assembly of the METOD series to design the space in a way that is practical and functional for people with limited mobility. Specifically, I have the following questions:
- How can I modify or adjust the height of the base cabinets to provide enough legroom for wheelchair users?
- Are there proven modifications regarding the choice and installation of drawers and pull-outs?
- What options are there for installing countertops so that they are easily accessible for wheelchair users without requiring special custom orders?
- How can the cabinets be secured to ensure stability while still allowing flexible adjustments?
I have read quite a bit already but am unsure about the best way to implement these changes practically. Thank you in advance for your helpful tips and experiences!
Hello melvinki,
to install METOD kitchen cabinets in an accessible way, the following points should be considered:
- Base cabinets should be set at a height of about 68 to 70 cm (27 to 28 inches) to provide enough legroom for wheelchair users – this usually means giving up the standard total height of 80 cm (31.5 inches).
- Instead of a continuous toe kick, it is recommended to use adjustable feet or raised platforms to make the height flexible and achieve knee clearance.
- For drawers and pull-outs, soft-close systems that operate smoothly are ideal. Also, handles should be either integrated handle strips or handleless fronts, as these are easier to operate.
- Countertops can be custom-cut and installed to achieve the lowest possible height. This can be supported with angled brackets that do not leave obstructive beams inside the base cabinet area.
If you need precise measurements for legroom: at least 70 cm (28 inches) in width and 65 cm (26 inches) in height should remain free. IKEA unfortunately does not offer special accessible modules, but the METOD system is modular and can be adapted well for this purpose.
I hope this helps you for now.
Hello melvinki,
I would like to add a short guide for installing METOD furniture in accessible kitchens. The assembly process is basically the same, but the adjustments come before and during the actual installation:
1. Preparation and Planning
- Measure precisely to determine the optimal height for users with mobility impairments. Depending on the user, the height of the work surface and cabinets may be between 70–75 cm (28–30 inches).
- Choose base cabinets without fixed plinths to keep the wheelchair area clear.
2. Installation of Base Cabinets
- Remove the standard plinths and instead install adjustable height elements or special work platforms.
- When fastening, ensure the construction is stable—use heavy-duty brackets that won’t loosen under movement or load.
3. Adjustment of Fronts and Fittings
- Handle solutions are important: handle rails or push-to-open systems make operation easier without requiring pulling forces.
- Soft-close fittings are useful so that moving parts close gently.
4. Worktop
- A custom worktop (e.g., made of stabilized, water-resistant material) should be mounted so that there is enough clearance underneath.
- Pay attention to fixings: maintain distances to prevent wobbling while making sure no cross supports interfere with legroom.
5. Electrical and Connections
- When planning sockets and connections, ensure they are easily accessible—mounted low with adequate protection.
Conclusion: The biggest challenge is maintaining the correct dimensions and achieving a stable but flexible installation. A combination of IKEA standard parts and custom additions is usually necessary.
If you want, I can gladly give you more tips on replacing standard plinths or suitable work platforms.
4. Worktop
sihau schrieb:
Base cabinets should be set at a height of about 68 to 70 cm (27 to 28 inches) to provide sufficient legroom for wheelchair usersThat sounds reasonable, but this is exactly where IKEA METOD becomes problematic since the modules are designed for standard heights. Sometimes it’s simply impossible to modify the furniture without reaching the limits of the construction – you end up assembling something makeshift. Anyone wanting a truly accessible kitchen needs to invest heavily or rely entirely on custom-made solutions.
onMarcos schrieb:
A combination of IKEA standard parts and custom additions is usually necessary.I completely agree. And I wonder if some users would be better off avoiding these ‘standard systems’ altogether. Of course, everyone wants to save money, but what’s the use of the cheapest kitchen if you constantly have to make adjustments and end up dissatisfied? For genuine accessibility, it’s smarter to invest more in tailored solutions that meet specific needs.
As long as IKEA doesn’t offer better options here, I see the METOD series more as an interim solution.
