ᐅ How do I install Ikea Metod kitchen cabinets with soft-close doors?
Created on: 24 May 2017 18:37
Tanstella
Tanstella
24 May 2017 18:37
Hello everyone, I am facing the challenge of assembling and adjusting Ikea Metod kitchen cabinets with soft-close doors. Since the system offers many customization options and the soft-close function is technically quite complex, I want to ensure that I approach the installation correctly to guarantee optimal operation and durability of the doors. In particular, I am interested in:
- What steps are essential during the assembly of the Metod cabinets with soft-close doors?
- How do I properly adjust the soft-close mechanism of the doors?
- Are there any tips to avoid common mistakes?
Thank you in advance for your help!
Brian
24 May 2017 19:11
Hello Tanstella,
I understand your concerns about installing the Metod kitchen cabinets with soft-close doors, as the door mechanism needs to be adjusted correctly. To summarize the sequence:
- Fully assemble the cabinet frame according to the instructions.
- Attach the hinges, including the soft-close mechanism, to the door panels.
- Screw the doors onto the cabinet, carefully hooking the hinges in place.
- Use the adjustment screws on the hinges to precisely align the doors vertically, in depth, and laterally.
- Test and fine-tune the soft-close mechanism. Ikea usually provides adjustment options on the mechanism that allow you to slightly modify the closing speed.
It is important that the hinges are mounted correctly, otherwise the soft-close function will not work properly. Also, thoroughly aligning the doors is crucial so the damping works smoothly and without damage.
Common mistakes often involve inaccurately placed screws, which can cause the doors to become misaligned or the dampers to jam. This results in uneven closing or even blockages.
If you have any further questions, feel free to ask!
Penau
25 May 2017 07:56
Brian schrieb:
With frequent issues, you should check for screws that are not tightened accurately, which can cause doors to misalign or dampers to jam.
I would like to add this point: Before final installation, it is essential to test the hinges multiple times on each Metod cabinet and retighten all screws by hand.
Furthermore, please note:
- The soft-close mechanism is usually pre-adjusted at the factory but can be fine-tuned with a small screwdriver on an adjustment control located on the hinge damper.
- Check the positioning of the hinges on the door panel against Ikea’s installation instructions to ensure proper load transfer.
- Use an appropriate screwdriver to avoid over-tightening or misaligning the metal parts.
Working precisely prevents damage to the hinges and interference with the mechanism. Also, double-check the alignment of the doors once installed to optimize the soft-close effect.
Marsar
26 May 2017 12:43
Penau schrieb:
Check the hinge positioning on the door panel against Ikea’s assembly instructions to ensure proper force transmission.
I completely agree with that. I assembled my Metod cabinets myself just last week and worked with the soft-close hinges. Here’s what I learned:
- The hinges should be installed as straight and tightly as possible. This works best using a cordless drill with the appropriate bit to avoid stripping the screws.
- The adjustment options of the Metod hinges allow for perfect door alignment – for this, use the two lateral adjustment screws (sometimes there is also a vertical one) and, of course, the depth adjustment.
- The soft-close effect feels significantly better when the doors are well aligned, as the damping is not overly strained.
- To adjust the damping, I found a small rotary screw on the mechanism that lets you regulate the strength of the braking action.
- Patience is required during adjustment – better to take small steps and test repeatedly.
If anyone is looking for the exact position of the screws on the door hinges: Ikea provides very helpful dimension tables, which are invaluable.
I hope this helps!
