ᐅ How do I install IKEA Metod kitchen cabinets with sliding doors?
Created on: 4 Jan 2023 09:17
alpayni10
Hello everyone, I am currently planning the installation of my new IKEA Metod kitchen and specifically want to fit the kitchen cabinets with sliding doors. My question is quite specific: How exactly do I install the Metod kitchen cabinets with sliding doors? I am particularly interested in what I need to pay attention to when preparing the cabinets, how the sliding door mechanism is attached, and if there are any special tips for adjusting the doors later to ensure smooth and stable operation. Are there common pitfalls to avoid when assembling this combination of cabinets and sliding doors? I would appreciate detailed explanations, as I have decent DIY skills but have not installed these types of doors before.
Here are some additional tips:
- Attach sliding door profiles carefully to avoid damaging the surface.
- When hanging the doors, ensure they do not become misaligned to prevent long-term mechanical stress.
- Use a screwdriver with a fine tip for the adjustment mechanisms to make precise adjustments.
- Avoid heavy loads on the doors, especially with Metod sliding doors, as they are not designed as load-bearing structures.
Following these steps will significantly extend the lifespan of the doors.
alpayni10 schrieb:
How much tolerance is there when installing the tracks?The tolerance is actually quite limited; in my case, there were only a few millimeters (inches) available for adjustment. Especially the bottom track needs to be perfectly level to avoid any binding.
CHENFAR schrieb:
A common mistake is not securely connecting the cabinets to each other, which negatively affects the sliding doors.I agree with that. If the cabinets aren’t properly nailed or screwed together, they can shift, and the doors won’t slide smoothly. It’s better to take some extra time and carefully check all the connections.
Assembly Tip: Work systematically and follow these steps to ensure stable and smooth Metod sliding doors:
- First, check the floor and wall for levelness using a spirit level and eliminate any unevenness with shims.
- Assemble the base cabinets exactly according to the instructions, using connecting fittings for stabilization.
- Install the track system with precise spacing—ideally allowing 1–2 mm (0.04–0.08 inches) of clearance; this is necessary for smooth movement without too much play.
- Carefully hang the doors, insert the rollers, and test the operation to ensure they move without effort.
- Adjust the doors by making small turns on the adjustment screws until they run parallel and flush.
A steady hand and patience are essential; there are no really difficult corners when assembling Metod sliding doors if the basics are right.
