ᐅ How do I install IKEA Metod drawers with a soft-close mechanism?
Created on: 31 Mar 2023 18:27
baunarHello everyone,
I am currently facing the challenge of properly installing IKEA Metod drawers with the soft-close mechanism. Since I already have some experience with furniture assembly, I want to make sure I carry out each step carefully to avoid later issues such as misaligned drawer slides or stuck soft-close components.
Specifically, I am interested in the following points:
- Which screws and tools are recommended to securely connect the Metod side panels and bottom panel?
- How exactly is the soft-close mechanism attached to the drawer box, especially regarding the positioning of the dampers?
- What should I pay attention to when aligning the drawer inside the cabinet so that the soft-close system works perfectly?
- Are there common mistakes during installation that I should be particularly careful to avoid?
If anyone has a step-by-step guide or helpful tips based on their own experience, I would really appreciate your support.
Thanks in advance for your help!
Hey baunar, great that you’re tackling this topic so thoroughly! 😄 A few months ago, I installed Metod drawers with soft-close myself, and I can tell you: it’s definitely worth taking your time!
It’s important to pay close attention to the orientation when tightening the drawer runners, so the drawer doesn’t get stuck later. I always screwed the runners in loosely at first, then hung the drawer, and only after that tightened everything properly – this way you can align them perfectly.
Regarding the soft-close feature: the dampers are located on the rear sides of the drawer runners and must be clicked precisely into the designated holes. It really helps to follow IKEA’s instructions step by step and not skip anything.
If you like, I can also share some tips on how to adjust the drawers if they don’t close perfectly. Keep at it, it’ll turn out great!
Hello baunar,
Your question about installing the IKEA Metod drawers with a soft-close mechanism deserves a detailed answer, as there are some technical details to consider.
For tools, I recommend a cordless drill with adjustable torque settings, Phillips and flat-head bits, and a protractor or angle finder to align the components precisely. The screws are included in the IKEA assembly kit; please use these as they are optimally sized.
The soft-close mechanism is usually located at the very back of the drawer slide. It is important to clean the surface of the slide before installation to ensure proper adhesion of the dampers. Gently press the dampers into their designated mounts until you hear a slight “click.”
When hanging the drawer, it is best to slightly loosen the mechanism first to allow the drawer to be inserted, then tighten the screws afterward. When aligning, make sure the drawer is parallel to the cabinet carcass. Measuring the gap on both sides helps with this. Also, check that the slides are mounted exactly parallel to each other, as otherwise the soft-close function may not work evenly.
A common mistake is placing the dampers too far forward or backward, which leads to uneven braking or noise when closing. You should also avoid tightening the screws too much so that the mechanism can still move smoothly.
I’d be happy to assist further if you could provide more precise measurements or photos of your setup—then I can give you more specific advice.
Surela schrieb:
The soft-close mechanism is usually located at the very back of the drawer slide.Exactly, that’s an important point!
Here is a brief step-by-step installation guide:
- First, connect the drawer’s side panels to the bottom and back panels, tightening all connections firmly but not over-tightening.
- Next, install the drawer slides on the cabinet’s side walls. Make sure the slides are perfectly level and parallel.
- Slide the soft-close dampers into the rear mounts of the drawer slides until they snap securely into place.
- Carefully insert the drawer into the slides, ensuring it sits evenly.
- Then, open and close the drawer several times to test the soft-close function.
- If necessary, adjust the alignment using the adjustment screws.
Common mistakes are usually that the slides are not mounted precisely at right angles or the dampers are not engaged correctly.
One more tip: avoid using an oversized screwdriver, which can more easily damage screws, and pay attention to the recommended tightening torque if specified.
If you have trouble with alignment, feel free to write again—I’m happy to help!
