ᐅ How do I assemble IKEA Metod drawers with soft-close mechanisms?
Created on: 26 Jul 2020 08:37
Z
zackaryf41
Hello everyone, I am currently assembling my IKEA Metod kitchen and have a question specifically about the drawer slides with soft-close mechanism. My question is: How do I install the Metod drawers so that the soft-close function works correctly? I already have the IKEA instructions, but they don’t seem very detailed regarding the damping mechanism, especially when it comes to hooking in and fine-tuning the dampers. Does anyone know the exact steps, or perhaps any tips on what to watch out for to ensure the drawer not only operates smoothly but also closes softly and quietly? Are there common mistakes or tricks during assembly and installation? Thanks in advance for your help!
Z
zackaryf4127 Jul 2020 07:19I’m checking in again: After reviewing everything once more yesterday and precisely positioning the dampers, it’s working much better now.
Is there a recommended way to test the soft-close function to ensure it operates evenly along the entire length of the drawer? I had the impression that if I close the drawer very gently, the damping doesn’t engage immediately. Is this normal, or should the damping activate right away?
The soft-close dampers are designed to activate only when the drawer moves at a certain speed and is close to the cabinet frame. This means that if you move the drawer very slowly and gently, the damping will not engage immediately.
For testing, I recommend closing the drawer at a moderate to fast speed and observing whether it closes smoothly and with damping.
Also, make sure there are no debris in the track channel and that the slides are installed cleanly, as this can otherwise affect their function.
barEsperan27 Jul 2020 09:45One more tip: Also check the position of the back panel in the drawer. If it is not properly seated, it can block the movement of the slide or the damper.
gekira schrieb:
The soft-close dampers are designed to activate only at a certain speed and proximity to the cabinet carcass.Exactly, and to control this precisely, the damper is located at the rear end of the runner, where a spring mechanism slows down the closing process. A frequently overlooked aspect is the proper engagement of the drawer into the cabinet frame. Even minimal play or misalignment here can prevent the damper from working optimally.
Also, if there is any sticking, check the alignment of the drawer front with the side panels. A slight adjustment using the screws on the front can make a significant difference.
If you like, I can send you a step-by-step guide for fine tuning.
