ᐅ How can I install IKEA Metod cabinets with soft-close features for added convenience?
Created on: 25 Aug 2024 17:43
KENRO48Hello everyone, I am currently planning to install several IKEA Metod kitchen cabinets at home and definitely want to include soft-close hinges and drawers to significantly improve comfort. My question is: How do I assemble IKEA Metod cabinets with soft-close systems so that they work optimally and are as durable as possible?
I am particularly interested in the following points:
- Which hinges and drawer slides are best suited for the Metod system?
- Are there any special considerations when installing or adjusting the doors to ensure the soft-close function operates smoothly and quietly?
- If you have any tips for retrofitting existing Metod cabinets with soft-close, please share.
I have assembled some furniture before and have basic experience, but I want to avoid mistakes that could cause problems later. Thanks in advance for your detailed advice!
Hello KENRO48,
I’d like to share a brief guide that covers the topic of soft-close for IKEA Metod cabinets in detail.
1. Choosing hinges and drawer slides:
- For soft-close doors on Metod, I recommend using the original IKEA Metod soft-close hinges, as they are perfectly matched to the system. Other brands often don’t fit exactly.
- For drawers, there are special soft-close drawer slides from IKEA, which you can buy as complete sets or separately.
2. Installation and adjustment:
- It’s important to mount the hinges loosely at first, then align the doors horizontally, vertically, and in depth using the adjustment screws.
- Soft-close works well only if the doors neither stick nor are too loose.
- The dampers on soft-close hinges should delay briefly and then softly brake when closing — check this by closing the door slowly.
3. Retro-fitting:
- If you already have Metod cabinets, you can buy soft-close hinges separately and replace the standard hinges.
- Sometimes a bit of patience is needed during fine-tuning, especially with older cabinets that may no longer be perfectly square.
My tip: Take your time to align everything precisely and only fully tighten the screws once everything fits perfectly. This is crucial for long-lasting enjoyment of the soft-close function.
I hope this helps!
3. Retro-fitting:
I hope this helps!
KENRO48 schrieb:
How do I assemble IKEA Metod cabinets with soft-close systems so they work optimally and last as long as possible?To be honest, is soft-close really the comfort booster that everyone here praises? Especially with budget kitchens like Metod, I wonder if it’s just a marketing gimmick. Sure, it feels premium at first – until the damper starts creaking or fails after a few years.
The more important question is whether the cabinet is built solidly and precisely, so that no tension occurs at all. Soft-close is then just the icing on the cake, which wears out quickly anyway. Don’t forget: the construction has to be right, or the “comfort” turns into a source of frustration.
My advice: invest more in some pro tips for alignment and erase any horror stories about soft-close from your mind. From my experience, soft-close in Metod cabinets hasn’t been reliable.
I can understand GALEO4’s point to some extent but would like to add that the success of installing soft-close mechanisms in IKEA Metod cabinets largely depends on careful alignment and the proper selection of components.
Details:
- IKEA hinges are specifically designed for Metod and, with precise adjustment, ensure reliable soft-close functionality.
- Make sure not to use older-generation hinges, as the technology has evolved and newer models provide better damping.
- For drawers, I recommend using IKEA’s original soft-close-compatible drawer slides, as they offer a balanced combination of pull force and damping.
If done precisely, soft-close definitely results in less wear and greater comfort – provided the drawers are not overloaded and the doors are handled with care.
Therefore, my advice is to focus on correct installation guidance; this determines the outcome more than just choosing the soft-close system.
Details:
Hello KENRO48,
I’d like to share some practical tips that, in my experience, are very helpful when assembling IKEA Metod cabinets with soft-close hinges.
- Preparation: Before starting, make sure all hinges and runners match the soft-close version (there are also standard variants), as assembly can be difficult otherwise.
- When attaching the hinges, first screw everything in loosely by hand. Then hang the doors and adjust their alignment using the adjustment screws. It helps to open and close the doors several times to identify any misalignments.
- Sometimes the soft-close function on the drawers feels a bit stiff during the initial assembly. A few days of use usually helps as everything “breaks in” properly.
- If you want to upgrade the doors completely to soft-close, it’s best to replace all hinges, since soft-close won’t work optimally otherwise.
I also had some minor difficulties following these points at first, so I recommend having some patience during assembly. Still, the added convenience is definitely worth it.
If you have any further questions, feel free to ask.
