ᐅ How do I install Ikea Metod cabinets in rooms with low ceiling height?
Created on: 19 Jun 2021 08:27
MATSJAHello everyone, I am planning to install Ikea Metod kitchen cabinets in my kitchen, which unfortunately has a lower ceiling height of only 220 cm (7 ft 3 in). However, the standard height of the Metod tall cabinets is 240 cm (7 ft 10 in), meaning that the standard version cannot be fully assembled in my space. My specific question is: What options are there to safely and securely install Ikea Metod cabinets with a lower ceiling height without compromising functionality? Are there any proven methods or alternatives you would recommend? I would appreciate any tips, including advice on adjusting the carcass, base, or using other components to ensure the installation is optimal.
I’m familiar with this problem, as I had a ceiling that was too low myself. What helped me was installing the cabinets only partially up to the ceiling and using a cover strip at the top to visually conceal the ‘missing’ space. It’s not perfect, but sometimes it feels better than forcing everything to fit. Don’t worry, there are solutions!
To save height with Ikea Metod cabinets in rooms with low ceiling clearance, the following technical options are available:
- Shortening the cabinet carcass frames (depending on the material and tools available, but use caution due to stability concerns)
- Using shallower upper or base cabinets (if storage space is sufficient)
- Installing a custom plinth or base that compensates for height from below to raise the cabinet accordingly
- Conceptual planning: combining a tall cabinet with a shallower element on top (e.g., upper cabinet or filler panel) to neatly adjust the overall height
Recommendation: Measure the total height including plinth, countertop, and any filler panels carefully before making alterations to ensure a proper fit.
meoreo schrieb:
You can raise the base cabinets a bit, for example with a taller plinth or an additional plinth trim piece. I think that’s a rather limited approach. The Ikea Metod system is modular and aims to serve the masses with its standard dimensions. Why not simply question the underlying principle? Instead of adjusting the cabinets to fit an unusually low ceiling, you could rethink the entire layout: more open shelving, smaller cabinets, or even integrating other systems. The strict Ikea Metod dimension standards don’t always have to apply.
