ᐅ How can I install Ikea Metod cabinets to maximize storage in a small space?
Created on: 28 May 2021 19:37
Dandelia
Dandelia
28 May 2021 19:37
I am planning to install several IKEA Metod cabinets in my small kitchen to make the best use of the available space and create as much storage as possible. Since my kitchen area is really limited, I am wondering how to maximize storage when designing and assembling the Metod cabinets. I am especially interested in how to best combine the choice of cabinet types, the arrangement (vertical or horizontal), and interior fittings.
Does anyone have experience with smart solutions, such as special inserts, different drawer options, or modular combinations that make the most of limited space? Tips on installation and planning for small kitchens would also be very helpful, as I have little experience with IKEA systems and the Metod range.
I look forward to your ideas and experiences!
ryan1
28 May 2021 20:02
Hi Dandelia,
that sounds really exciting! Metod is indeed a flexible system that lets you get a lot out of it! 😊 I can only recommend measuring everything precisely first and then experimenting with IKEA’s planning tool—it helps you optimize the cabinets to fit your space perfectly.
In my small kitchen, I used extra-tall cabinets (2.4 m (7 ft 10 in)) to make use of the height. Also, drawers are real storage champions: you can store small items at the back that you might otherwise easily forget.
One more tip: internal pull-outs for spices or baking trays are very practical and save wall space. Also, consider wall cabinets that leave the floor clear to create a sense of openness. Good luck, you’ve got this! 💡🔥
PAR63
28 May 2021 21:48
Hello Dandelia,
I would like to suggest a structured approach:
- Step 1: Measure the room and determine the exact dimensions, including ceiling height.
- Step 2: Prioritize storage needs, considering how often you use items (e.g., everyday dishes at the bottom, rarely used items at the top).
- Step 3: Choose the cabinet types. For a small space, I recommend basic base cabinets with drawer fronts, as they are accessible and organized.
Please note:
- The depth of Metod cabinets (60 cm standard) may be too much for small rooms; consider narrower cabinet bodies (40 or 37 cm) if necessary.
- Use interior fittings like VARIERA inserts effectively, for example, adjustable shelves, cutlery trays, and drawers with telescopic slides.
Regarding installation:
- Make sure to securely anchor the cabinets, as tall cabinets in tight spaces can easily tip over.
- When assembling multiple modules, ensure precise alignment so that all doors close smoothly.
Summary: Careful planning, targeted use of interior fittings, and choosing appropriate cabinet widths will help you create plenty of storage even in a small space.
TELAHAU
29 May 2021 08:16
Use IKEA’s Metod cabinet planner and take exact measurements.
Tall cabinets with drawers in front are very helpful.
Optimize internal organization using Variera elements.
Make sure to use corner cabinets efficiently.
RENMA
29 May 2021 10:47
Regarding your concern: Increasing storage space in limited areas is achieved by utilizing the vertical height of the room and minimizing unused space between cabinet sections.
I recommend:
- Choosing the maximum cabinet height (up to 240 cm (94 inches)) to store items that are rarely used.
- Combining pull-out drawers and doors with adjustable shelves, as drawers are more efficient than open cabinets.
- Using high-load capacity inner drawers, as they can hold more weight and volume.
- In small kitchens, narrow cabinets (30-40 cm (12-16 inches) wide) can be more practical to improve access and keep escape routes clear.
Additionally, ensure proper alignment during installation, paying attention to squareness and straightness to minimize gap sizes.
kogudra
29 May 2021 16:32
PAR63 schrieb:
Make sure to secure the cabinets firmly, as tall cabinets can easily tip over in tight spaces.
This is a very important point. Additionally, I recommend checking potential wall thicknesses and their condition during planning. Sometimes not all walls are load-bearing enough to support the upper row of cabinets, especially in older buildings.
IKEA Method cabinets often rely on modular connections. Use these connections to link multiple cabinets together, which increases stability.
For storage, I suggest fully utilizing the interior space with suitable inserts. In small areas, it is crucial to avoid wasted space.
