I am currently facing the challenge of installing IKEA Metod kitchen cabinets in a very tight space. My available area is severely limited, both in width and depth, so the standard dimensions of the IKEA cabinets hardly fit.
This concerns a small kitchen in a rental apartment, where I cannot make any wall modifications or major structural changes. It is important for me to mount the cabinets as space-efficiently and securely as possible to prevent tipping or wobbling, while still keeping them practical to use.
Does anyone have experience with assembling Metod cabinets in very restricted spaces and possibly customizing them? Are there any tips for measuring, the order of assembly, or choosing cabinet types that could help?
I appreciate any constructive suggestions and experiences that are useful—feel free to include advice on tools or alternatives for unusual spatial situations.
Best regards!
Best regards!
Hello riusmeo,
I have assembled Metod cabinet systems in tight spaces several times and would like to share some structured tips that might make your installation easier:
- Accurate measurements: Measure your room multiple times at different points, as even small irregularities can cause issues with IKEA cabinets.
- Create a floor plan: Draw your room to scale on paper or digitally. This way, you can test different cabinet combinations before you start the assembly.
- Choose cabinet types: For narrow spaces, Metod base cabinets with widths of 40 or 60 cm (16 or 24 inches) are usually the most practical. Use shallower options if depth is limited, as 37 cm (15 inches) deep modules are also available.
- Assembly order: Assemble individual modules completely first, then connect them side by side without attaching them to the wall yet. This allows for better adjustment and corrections.
- Ensure wall mounting: Use appropriate anchors and screws suitable for your wall type (drywall, masonry, concrete). Stable anchoring is often underestimated, especially in small rooms where there is little margin for error.
- Reinforcements: If possible, use additional brackets or cabinet connectors for extra stability. While IKEA provides connectors for Metod, adding extra brackets or angle profiles can improve sturdiness.
- Use adjustable feet: Leveling feet help compensate for uneven floors and provide a secure stand.
- Additional tip: If door space is tight, consider sliding doors or glass splashbacks for shelving.
I hope this helps you get started. If you can provide specific measurements, I can offer more tailored suggestions.
Best regards!
Best regards!
Hello riusmeo,
I can only agree with LOJOPAR and would like to add that besides taking accurate measurements, it is important to consider how you plan to use the cabinets later. A common mistake in tight spaces is to only plan the footprint, without factoring in the opening radius of cabinet doors and drawers.
- If you keep this in mind, you might consider installing toe-kick drawers, pull-outs, or even wall cabinets with reduced depth in certain areas.
- Less common cabinet types, such as wider base cabinets with drawers beneath the countertop, often provide more storage space while taking up less floor area.
- Also, pay attention to the assembly sequence: sometimes it helps to first attach the side panels and position the units loosely in the room before securing the back panels or fronts.
- If possible, you should also firmly attach the cabinets to the wall. This is an important safety measure, especially when space is limited.
One more thing: check if the floor is level. Small unevenness can be easily compensated using adjustable feet.
A little patience during assembly always pays off. Good luck!
LOJOPAR schrieb:
First, fully assemble individual modules, then connect them together at the sides, but do not yet fix them to the wall. This way, you can adjust and make corrections more easily.I can totally confirm this. I had a similar experience when I installed the kitchen in my small apartment. At first, I was really unsure if the parts would even fit properly, since the space was unusually narrow.
Loosely assembling and shifting the modules gives you a lot of flexibility and reduces the pressure.
- I also found it important to have enough time – no rushing during assembly, so you have the patience for small adjustments.
- Additionally, I constantly checked with a spirit level to ensure everything was straight.
Even if the space is tight, good planning and working step-by-step can lead to surprisingly good results. That also boosts confidence on larger projects.
Maybe you can rely on your experience and stay pragmatic despite the tight space.
Good luck!
Important: Measure everything multiple times, especially in tight spaces.
- Assemble the cabinets completely first.
- Try different positions without screwing anything.
- Secure with mounting brackets and attach to the wall.
Also: Check doors/swing panels for their opening radius.
This usually works well.
gilen schrieb:
A little patience during assembly always pays off here. I'm keeping my fingers crossed for you!I definitely want to emphasize this as well. It really helped me back then to see the assembly as a small process and a learning step, rather than trying to do everything at once.
Also, it was emotionally important for me not to get frustrated and give up immediately over minor problems. Especially in tight spaces, small issues can quickly become unexpected time sinks.
If you notice that space is too tight during assembly, try putting together the modules in larger sections or even completely outside the room, then do only the final assembly in place.
Even if it sounds cliché: giving yourself time and being patient with the process often leads to better results than trying to rush through everything.
I wish you lots of success and hope your project goes well and brings you joy in the end!
