ᐅ How do I assemble IKEA Metod cabinets with custom measurements?
Created on: 15 Dec 2015 08:27
Baulis
Baulis
15 Dec 2015 08:27
I am currently planning to assemble IKEA Metod kitchen cabinets, but I need to customize some of them with adjusted dimensions, so they won’t match the exact sizes listed in the catalog. My question is: What is the best way to modify or adapt the Metod cabinet modules to fit precisely into my niches?
I’m especially interested in whether it’s allowed to cut some parts, what assembly instructions need to be considered, and if there could be any issues regarding stability or the functional design. It would also be helpful if anyone has experience with customizing the interior fittings.
I look forward to your advice, especially proven methods, recommended tools, and tips on what to avoid!
Deoren
15 Dec 2015 09:03
Baulis schrieb:
What is the best way to modify or adjust the Metod cabinet modules so they fit exactly into my recesses?
In short: You can cut the cabinet boxes to size as needed using a good circular saw, but you should not shorten the doors and fronts. This affects both stability and appearance.
barge
15 Dec 2015 10:18
Deoren schrieb:
You can cut the carcasses as needed with a good circular saw
Exactly, cutting the carcasses is the key! I did this last year – just measure, mark, and then make clean cuts with a fine-toothed saw blade.
- Tip: Pre-drill the cut lines or use guide rails to keep everything straight.
- Doors? Better not cut them, or the finish will chip and the doors might not close properly.
And don’t worry, with the right tools it goes smoothly. You really feel like a professional carpenter afterwards 😄.
HORST41
15 Dec 2015 14:42
I understand well what Baulis means. Such adjustments can definitely cause headaches, especially if you feel uncertain.
A small tip from my experience: If you shorten the carcass, be careful not to damage the drill holes or connection points. This can affect stability and make assembly more difficult.
barge schrieb:
Doors? Better not to saw them, otherwise the paint will come off and the doors won’t close properly.
Exactly, and sometimes it’s better to use special IKEA components with particular sizes if available.
Don’t worry too much about cutting, but allow enough time and try it out first in less visible areas.
BOSUDA
15 Dec 2015 16:05
I would also add: Always use a fine pencil and a set square for marking. This helps to avoid inaccuracies.
Additionally, screwdrivers with torque control are useful to prevent over-tightening connections.
Wood protection is important, so pre-treat cut edges with clear varnish.
Deoren
16 Dec 2015 08:41
That’s a very good point. I would add: if drill holes are cut through, you will need to drill them again; otherwise, the dowels won’t fit properly.
BOSUDA schrieb:
Wood protection is important, so pre-treat any cut edges with clear varnish.
Always important, especially in kitchens where there is moisture.
