ᐅ How do I install IKEA Metod kitchen cabinets to fit sloped ceilings?
Created on: 23 May 2024 08:23
SARNU
I am facing the challenge of installing IKEA Metod kitchen cabinets so that they fit perfectly under a sloping roof in the attic. My roof slope is about 35 degrees, and I want to make the most efficient use of the cabinets without any gaps forming later or the doors not closing properly. My idea was either to adjust individual cabinets at the top or possibly make custom cuts to the top panels – however, I am unsure of the best approach to maintain stability and avoid compromising the appearance.
I am also interested to know if anyone has experience with modifications or adapter parts that IKEA offers for Metod, or if custom solutions are generally more practical.
What steps would you recommend to ensure the cabinets fit precisely against the roof slope? Are there any specific considerations I should keep in mind during installation, especially regarding fastenings or door hardware?
I look forward to your tips and advice!
SARNU schrieb:
Has anyone had experience with custom-fit doors for sloped ceilings? Do I need to cut the doors myself, or are there good solutions from IKEA or third-party suppliers?IKEA Metod does not typically offer doors designed for sloped ceilings. The doors come in fixed sizes and shapes, so adjustments usually require cutting them yourself or creating additional custom elements.
Recommended approach:
- Cutting doors: Using a fine saw (e.g., Japanese pull saw or electric saw with a fine blade), doors can be trimmed at the top or bottom edge to fit slight slopes.
- For steeper angles, wooden triangular inserts can be added along the slope where the doors are attached.
- Alternatively, modular additions like open shelving units or trim panels can be used without cutting the doors directly to blend in the appearance of the slope.
It is important to inspect the door thoroughly from all sides before cutting, especially the finish and edges, to prevent chipping or splintering.
Maintaining door stability and function is possible if cutting is done precisely. Purchasing from third-party suppliers may be an option depending on the country and availability, but it is often costly and not always an exact fit.
Filippo schrieb:
I’m curious about the maximum cabinet height you’re planning and whether there will be appliances or work surfaces underneath.I really like the relaxed approach you’re taking here! With a sloped ceiling, you can never be quite sure of the exact measurements – so keep your eyes open and measure one more time than you think you need.
I completely agree with the idea of using individual battens or mounting strips. They don’t just add stability but also provide a nice finish that looks neither sloppy nor makeshift.
A little tip: If you’re trimming the doors yourself, take your time – don’t worry, it might seem complicated at first, but with the right saw and some patience, it will turn out great!
It’s nothing complicated, just a bit of “IKEA magic” under a slope 😉
