ᐅ How can I install Ikea Metod cabinets in tight kitchen spaces to save room?
Created on: 25 Dec 2024 08:37
svenne
svenne
25 Dec 2024 08:37
I am planning to install new IKEA Metod cabinets in my relatively narrow kitchen to make the best use of the available space. My main challenge is that the room is very narrow and not ideal for wide cabinet combinations. I am wondering how to arrange and install the Metod cabinets in a space-saving and functional way without significantly restricting movement or accessibility.
Are there any proven tips or experiences on how to best work with the Metod system in tight kitchen spaces? I am particularly interested in whether it makes sense to choose specific cabinet types or widths, whether to focus on interior fittings that maximize storage capacity, and how to plan the entire setup so that working in the kitchen remains comfortable.
I look forward to your feedback—especially general guidance or ideas on the optimal distribution of cabinet sizes and installation options. Thanks in advance!
Davidleo
25 Dec 2024 12:15
Super interesting question! I love getting the most out of small, narrow kitchens! 😊
My tip: Use narrow cabinet widths of 20 or 40cm (8 or 16 inches) instead of the standard 60cm (24 inches). This way, you can better divide areas and create more room to move. Also, be sure to check out corner solutions, especially those with carousel mechanisms, offered by IKEA! They allow you to cleverly use a lot of storage space.
Pull-out drawers and baskets inside cabinets are also invaluable, as they let you fully utilize deep cabinets. Don’t hesitate to use the maximum cabinet height to optimize vertical space. There are also wall cabinets with reduced depth – these are great for narrow kitchens.
Stay tuned, I can give you more tips once you have more details. You’ve got this!
Palenar
26 Dec 2024 09:02
Hello Svenne,
your question about the optimal design of IKEA Metod cabinets in tight kitchen spaces deserves a detailed look. Generally, I recommend starting with precise measurements of all room dimensions, including doors, windows, and electrical outlets. This allows you to choose cabinet widths that fit perfectly, as the Metod modules come in widths of 20, 40, 60, 80, and 100 cm (8, 16, 24, 31, and 39 inches). For narrow rooms, 20 cm (8 inches) and 40 cm (16 inches) modules are very useful because they can be combined flexibly and require less space when opening the fronts.
Davidleo schrieb:
Use narrow cabinet widths of 20 or 40 cm (8 or 16 inches) instead of the standard 60 cm (24 inches).
In addition, Metod offers shallow upper cabinets with a depth of 20 cm (8 inches), which can be effectively used in the upper area to optimize headroom and usable height.
An important point is access to the contents: I recommend internal pull-outs instead of traditional shelves, as these provide better visibility and are easier to reach in deep cabinets. For corners, "Magic Corner" or "swing-out drawers" are particularly space-saving, although in very tight kitchens the usable storage space can be reduced by the swing arms.
Additionally, you should plan the door opening direction and, where possible, rely on pull-outs and drawers, as these are easier to handle in everyday use.
To assist you better: How wide is your kitchen space exactly? Is there already an existing layout, or are you planning from scratch?
KAULIS
26 Dec 2024 14:47
From a structural perspective, there are several key factors to consider for narrow kitchen spaces using IKEA Metod:
- Take precise measurements of the kitchen, including ceiling height
- Use 20 cm (8 inches) and 40 cm (16 inches) wide base cabinets to organize the space flexibly
- Employ shallow wall cabinets with 20 cm (8 inches) depth to save space
- Choose pull-outs and wire baskets to maximize storage capacity
- Use corner solutions, preferably carousel or magic-corner units, to avoid dead corners
- Opt for full cabinet height to optimize vertical space
- Carefully plan door opening directions and consider modifying door swings if necessary
The challenge is that narrow rooms are often less than 2 m (6 feet 6 inches) wide. While standard cabinets are 60 cm (24 inches) deep, shallower cabinets offer advantages, especially for wall units.
Palenar schrieb:
Additionally, you should plan the door opening direction and, where possible, rely on pull-outs and drawers, as they are easier to handle in everyday use.
This is important because in tight spaces every movement around cabinet fronts must be carefully considered. Overall, I highly recommend using CAD planning or IKEA’s 3D software to simulate the space before making a purchase.
Elijah42
27 Dec 2024 07:29
Choose narrow cabinets, preferably 20 or 40 cm (8 or 16 inches) wide.
Use pull-out drawers instead of shelves.
Install a carousel unit for corner spaces.
Opt for shallow upper cabinets.
Make full use of the vertical height.
Jensson
27 Dec 2024 10:34
Hello Svenne,
I am happy to provide you with a step-by-step guide for installation in tight kitchens:
1. Preparation: Remove all furniture and carefully measure the width and height, including windows and doors.
2. Planning cabinet widths: It’s best to use 20 cm or 40 cm (8 inches or 16 inches) wide modules, as these allow for more flexible arrangements.
3. Corner cabinets: Choose between carousel or magic corner fittings to fully utilize storage space in corners. Depending on the room depth, this can be especially important or sometimes problematic.
4. Interior fittings: Pull-out shelves and side drawers are particularly space-saving and ergonomic.
5. Wall cabinets: Shallow cabinets with a depth of 20 cm (8 inches) create open space above the work area, reducing the feeling of crampedness.
6. Pay attention to door opening direction to avoid collisions with walkways.
7. Installation: Start with the fixed cabinets, ensuring they are perfectly plumb so that nothing gets stuck.
Tips:
- Group cabinets of the same height
- Consider your requirements for countertop space
If you have any further questions about the implementation, I am happy to help!
