ᐅ How can I install Ikea Metod cabinets on uneven tiled floors?
Created on: 8 Jul 2023 11:23
gertdo
gertdo
8 Jul 2023 11:23
I am facing the following challenge: I want to install several Ikea Metod kitchen cabinets at home. Unfortunately, the tiled floor in the kitchen is not level and has noticeable unevenness, both along the tile joints and on individual tiles. My specific question is: How can I ensure that the Metod cabinets are installed stable, level, and securely on this uneven tiled floor without the structure being damaged or wobbly over time?
What methods or tools would you recommend to compensate for the unevenness? Are there special adjustable feet, leveling plates, or other options that work well? Do you need additional materials or special components?
I would appreciate any detailed advice, as I am familiar with the cabinet system but am not sure how to work properly with uneven floors. Thanks in advance for your tips!
jan10
8 Jul 2023 13:07
The adjustable feet from Ikea are specifically designed for uneven floors.
Adjust each foot individually until the cabinets stand level.
If necessary, use a spirit level to check during the assembly.
Domau0
9 Jul 2023 09:42
Hello gertdo,
your question is very practical, as tiled floors often have small height differences that can cause problems when assembling METOD cabinets.
The adjustable feet are indeed the main tool to compensate for unevenness. However, you should adjust the feet not just by feel, but systematically using a good spirit level. The following procedure is recommended:
- Assemble the cabinet carcass roughly
- Place the cabinet in the intended location
- Check the alignment with a spirit level first crosswise and then lengthwise
- Adjust each foot until the level shows the cabinet is horizontal
If the unevenness is greater (more than about 5 mm (0.2 inches) difference), it may help to use suitable shims (e.g., made of wood or plastic, sturdy enough) under the feet. This improves load distribution and prevents rocking.
Make sure the shims are non-slip. Additionally, I recommend fixing the cabinet to the wall to ensure high stability. This is especially important for heavily loaded kitchen cabinets.
Regarding special parts: Ikea themselves do not offer alternative feet with greater height, but third-party suppliers sometimes provide taller adjustable feet. If you need stronger leveling, this could be an option.
One more tip: If possible, measure the floor unevenness beforehand with a long straightedge or a spirit level. This will help you estimate whether adjustable feet alone are sufficient or if floor shims are needed.
I hope this helps you with your assembly!
PeoDaniel
10 Jul 2023 17:56
Hello gertdo,
I would like to add a few points since dealing with uneven floors when installing Ikea Metod cabinets is often challenging.
First, you should make sure the floor is really clean and free of dirt or small stones before setting up the cabinets – otherwise, this can also cause stability issues.
Second, besides the Ikea adjustable feet, there are so-called leveling mats or anti-slip pads that you can place under the feet. These are thin, flexible, and ensure the feet do not slip on smooth tiled floors. Especially if you only need to compensate for slight unevenness, they are an inexpensive and simple solution.
Third, one of the most important points is to firmly secure the cabinets to the wall after leveling them. This is recommended in the Ikea instructions anyway, but it is particularly crucial on uneven floors to prevent wobbling and achieve a strong anchoring.
If necessary, you can use so-called "shims" or spacers to compensate for small gaps at the back of the cabinet if it still doesn’t sit fully flush against the wall.
One more thing about the feet: if they don’t offer enough height adjustment, you can also buy standard furniture glides with M8 threads, which provide more adjustment height. This is especially useful for sloped tiled floors.
I hope these details help you complete your Metod installation smoothly!
