Hello everyone, I am facing the problem of installing an Ikea Metod kitchen unit on a floor that is not completely level. The subfloor has slight unevenness of about 1 to 2 cm (0.4 to 0.8 inches) over a length of nearly 3 meters (10 feet). My specific question is: How can I install the Metod cabinets so that they are stable and level on such an uneven floor, ensuring that the cabinet doors close properly later without any stress? Are there proven methods or special adjustments during installation, such as different legs, leveling pads, or particular assembly steps, that I should consider? I look forward to any tips and experiences, as I want to solve this as professionally as possible.
Andre52 schrieb:
How can I install the Metod cabinets stably and level on such an uneven floor, so the cabinet doors close properly later and no stress occurs?This is a very sensible question, as Metod cabinets are sensitive to uneven floors. I recommend assembling them in three steps:
- First, you need to measure the unevenness precisely. Ideally, use a long spirit level or a laser level to determine the height differences between various points.
- Second, Ikea offers adjustable legs that can generally raise or lower the cabinets by 8-10 cm (3-4 inches). Do not install the cabinets directly on the floor; instead, level them using these legs. If a 2 cm (0.8 inch) height difference cannot be locally compensated, you can use additional leveling pads under the cabinets.
- Third, if the unevenness extends over several meters, I recommend installing the baseboards only at the very end. By laying a continuous wooden board perpendicular to the slope as a substructure, you can level the cabinets on top.
A combination of adjustable legs and, if needed, a substructure is usually the best approach. Also make sure to securely fasten the cabinets to the wall — this helps with alignment and provides stability. A common mistake is placing the cabinets directly on the floor without leveling, which causes long-term problems with doors and drawers.
If you like, I can provide an example assembly sequence with additional tips.
Jensson schrieb:
Also make sure to securely fasten the cabinets to the wall – this helps with alignment and provides stability.A very important addition! Especially with uneven floors, it is essential that your Metod cabinets are screwed to the wall. Only then can they be properly stabilized and aligned so that the doors hang straight and nothing is crooked.
I would like to share a few basic tips:
- Always use a tape measure and a spirit level when installing the feet. Especially in maisonettes or older apartments with uneven floors, the height can vary significantly at different points.
- Check whether your floor is structurally stable. If the floor creaks or flexes, alignment problems can occur later if the cabinets shift.
- It might be worth placing a thin OSB board or plywood underneath as a base, positioning it to create a consistently level surface.
- Ikea Metod feet can be combined with small wooden blocks or felt pads to compensate for minor irregularities.
- When fitting the doors, make full use of the adjustment screws on the Metod hinges – they allow up to 2cm (0.8 inches) of correction in all directions to compensate for slight misalignments.
I hope this helps!
To approach the problem more thoroughly, you should also carefully check the angle of the room walls and the condition of the floor. Sometimes unevenness within the wall itself causes uneven gaps between the cabinet and the wall or doors that don’t close properly.
One method I recommend is:
- Before installation, check the floor with a laser level. From this, you can create a height chart.
- Then lay a sturdy, as level as possible base on the installation area (e.g., an 18 mm (0.7 inch) plywood sheet), which you level out at the necessary points. On this, you can position the Metod cabinets and precisely level them using the adjustable feet.
- Avoid adjusting the feet directly on the floor if the floor is not stable. An unstable base leads to permanent stress in the structure.
- When you connect the cabinets, slight misalignments can be compensated for, provided the wall attachment is also stable.
- Finally, check all doors again for smooth operation and even gaps.
Therefore, I recommend investing time in precise preparation. This will pay off later when using the cabinets.
