ᐅ How do I install Ikea Metod cabinets in small kitchen spaces?
Created on: 13 Sep 2022 09:33
gekar
I am currently planning to equip my small kitchen with Ikea Metod cabinets and am a bit uncertain about the best approach—especially due to the very limited space and unusual room dimensions. My kitchen is only about 6 square meters (65 square feet), and I want to make the most of the available space without the cabinets feeling too bulky or impractical.
I am particularly interested in how to proceed with assembly when modifications are needed for smaller or deeper cabinets. For example, should different shelves be used, or should the cabinets be assembled differently than described in the instructions?
Additionally, it would be helpful to get tips on how to maximize storage space with Metod in small kitchen areas without overly restricting movement. Which combinations of cabinet types and fronts are recommended in such cases?
I look forward to your experiences and advice!
liRaul49
14 Sep 2022 10:54
For small kitchen spaces, simply use narrower cabinets ranging from 20 to 40 cm (8 to 16 inches) in width. Corner cabinets with carousels or swing doors save space. Tip: When assembling, do not tighten screws too much so adjustments can be made later.
TEOZAR
14 Sep 2022 12:33
Hello gekar,
Small kitchens require careful planning and a realistic assessment of how much storage space you actually need. Metod offers cabinets with adjustable depths (40 or 60 cm (16 or 24 inches)) – the 40 cm (16 inches) version is often a good choice for small kitchens since it takes up less space.
Tinaneo schrieb:
In my opinion, this should be considered during installation, not afterwards.
Absolutely correct. When installing, you should position the cabinets to ensure the most efficient access and avoid doors blocking each other. The choice of cabinet fronts also matters: smooth, light-colored surfaces visually enlarge the space.
Additionally, I would recommend taking sockets and water connections into account during installation so you don’t have to dismantle cabinets later.
During assembly: it’s best to follow Ikea’s provided instructions step by step, but take your time and always work with two people. This will save you trouble later on.
baupau
14 Sep 2022 15:21
I first assembled all the Metod cabinets without doors and then checked the storage space in the smaller room. This way, you can better assess whether the shelves need to be repositioned. Corner cabinets with a carousel provide good access to the space. In small kitchens, be sure to pay attention to the cabinet height to avoid a bulky appearance.
