ᐅ How do I assemble Ikea Metod cabinet doors with soft-close hinges?
Created on: 7 Mar 2022 18:23
Chloe
Chloe
7 Mar 2022 18:23
I am currently facing the challenge of assembling the doors of my new Ikea Metod kitchen cabinet with the soft-close feature correctly. Although the instructions are included, some parts are a bit unclear, especially when it comes to installing the soft-close dampers and accurately hanging the doors.
I am particularly interested in how to attach the dampers properly, so the doors close smoothly and quietly, without sticking or jamming. It would also be important for me to know how to adjust the doors correctly to achieve the perfect gap between adjacent fronts.
Does anyone have experience with this exact cabinet door model and can explain step by step what I should pay attention to in order to avoid mistakes? Maybe also tips on handling the hinges, since they seem a bit delicate.
Thank you in advance!
chen67
7 Mar 2022 19:45
Hi Chloe,
"I'm mainly interested in how to correctly install the dampers so that the doors close smoothly and quietly, without sticking or jamming."
I can jump right in! 😊 The soft-close dampers on the Metod doors are actually quite cleverly designed. It’s important that you first securely screw the mounting plate to the cabinet body. The position is crucial: if the plate is crooked, the damper will jam later on.
After that, the damper clicks onto the plate, kind of like Lego, but easier. Make sure not to bend it or press too hard – nothing should be forced. Once everything is in place, you can hang the door, which also clicks into place.
Then comes the adjustment: the adjustment wheels on the hinge allow you to fine-tune the door’s position—horizontally, vertically, and in depth. Sometimes a little fine-tuning helps until everything operates smoothly and the gap to the adjacent cabinet is correct.
By the way, take a coffee break now and then – it helps keep your patience up and makes screwing around even more fun 😄.
If you want a detailed step-by-step guide, just let me know!
Surela
8 Mar 2022 07:14
Hello Chloe,
I would like to provide a more detailed response to your question based on my experience, as the soft-close hinges on Ikea Metod cabinets can be a bit tricky if you are not very precise.
First of all, when installing the hinges and dampers, please note the following:
- Attach the mounting plate exactly according to the instructions, at the correct height and with the correct distances to the cabinet frame. A difference of one millimeter can be crucial, otherwise the hinge will not close properly.
- The soft-close dampers are located on the inside of the hinge pin. For correct assembly, the hinge arm must be clicked properly into the mounting parts without using force.
- Before tightening all screws fully, it is advisable to roughly adjust all positions per door and hang the door provisionally to allow easy adjustments.
- For fine tuning, there are three adjustment screws: horizontal for the distance to the adjacent door, vertical for height alignment, and the screw for adjusting the depth to control the gap to the cabinet front.
- If the door is too far forward or recessed at the hinge side, the soft-close damper cannot engage properly, and the mechanism will not work as intended.
- Tip: Use a spirit level or a ruler to check the alignment, especially when installing multiple doors side by side.
- After installation: Test the door closing several times and adjust as needed until the soft-close functions smoothly and quietly.
To assist you better: Do you have the standard version of the hinges or the XXL variant? Are the doors made of glass or wood? These details slightly affect the installation.
I am happy to help you with any further questions!
jaanda
8 Mar 2022 09:53
Surela schrieb:
The soft-close dampers are mounted on the inside of the hinge pin.
Exactly, that is an important point.
I would like to add: The soft-close function works technically through a hydraulic damper inside the hinge, which slows down the door closing process. Therefore:
- When installing the hinge, be careful not to damage this damper – it must not be bent or compressed.
- When adjusting the door, all three screws should be turned carefully and in small increments to avoid misalignment.
- Mounting plates often have markings to help align the hinges – pay close attention to these.
- Finally, be sure to test the function several times: open the door fully, then close it gently, and listen for the soft-close to operate quietly and reliably.
- If it sticks, it can help to loosen the hinges again, slightly reposition them, and then tighten again.
If your doors hang incorrectly due to improper installation, don’t give up too soon. Attention to detail makes all the difference here.
A small tip: never tighten screws too much, so the materials don’t get damaged.
Good luck with the assembly!
