ᐅ How can I assemble IKEA HEMNES furniture to make it especially sturdy?
Created on: 12 Aug 2023 10:23
RidriesHello everyone, I plan to assemble some IKEA Hemnes furniture, specifically dressers and a wardrobe. It is important to me that these pieces are especially sturdy since they will later carry a lot of weight and will also be moved frequently. My question is: How can I assemble IKEA Hemnes furniture to make it as stable as possible?
I am particularly interested in details to watch for during assembly – for example, regarding metal fittings, screws, or the use of additional reinforcements. Are there any special tips that go beyond the assembly instructions to make the furniture more durable and robust? Perhaps also advice on suitable tools or the best approach when putting it together?
I look forward to your recommendations and experiences!
Hello Ridries,
First of all, thank you for the detailed question! I have assembled HEMNES furniture several times myself and would like to provide you with a structured explanation of what to pay attention to in order to make the furniture especially sturdy.
1. Preparation:
- Sort all parts and tools beforehand. A cordless drill with adjustable torque is ideal to avoid overtightening screws.
- Check the quality of the screws; sometimes replacement screws are better if you notice wear or slight damage.
2. Assembly:
- Assemble on a soft surface (e.g., blanket or carpet) to avoid damage.
- Always connect components exactly according to the instructions so the pre-drilled holes align properly. Misaligned connections can reduce stability.
3. Reinforcements:
- For additional strength, you can add small metal angle brackets at key joints, especially for dressers that will bear heavy loads.
- For wall cabinets, I recommend using your own screws with suitable wall anchors in addition to the IKEA fasteners.
4. Final check:
- Retighten all screws slightly after 24 hours, as wood often settles a bit.
A common mistake is not attaching the back panel properly or only loosely. The back panel provides lateral stability and should be fully secured with all nails or screws.
I hope this helps you. If you have more specific questions, feel free to ask!
1. Preparation:
2. Assembly:
3. Reinforcements:
4. Final check:
teyosef schrieb:
A common mistake is not attaching the back panel properly or only loosely.I can only confirm that – besides the metal fittings, the back panel is one of the most important factors for the stability of a HEMNES furniture piece.
I would recommend assembling it in even more detail as follows:
- Screws: Make sure to use a suitable Phillips screwdriver to avoid any minor damage to the screw head. When using a cordless drill, the torque limiter is essential. Tighten just enough, not too much!
- Fasteners: HEMNES uses a combination of wooden dowels and metal screws. The dowels provide alignment, the screws the clamping force. For joints with high stress – such as pillar feet or the top edges – you can add some wood glue to the screws. Don’t worry, this won’t damage anything; the glue ensures a permanently strong connection.
- Back panel: In addition to the specified nail or screw set, consider using thin screws if the plywood back panel tends to loosen slightly.
- Assembly surface: Always work on a flat, horizontal surface to prevent warping during assembly.
Additionally: When connecting furniture pieces – for example, a chest of drawers to a sideboard – use metal angle brackets to stabilize the unit.
I’m also interested to know whether you plan to screw the furniture together or just assemble it loosely?
I hope this gives you practical value and I look forward to hearing more from you!
kulau schrieb:
Always work horizontally and on a level surface to avoid deformations during assembly.Absolutely! I completely agree: if you assemble the furniture crooked, even the strongest screw won’t help. But don’t worry, with a few simple tricks everything will go smoothly!
My personal tips:
- Take your time during assembly, don’t rush. Sometimes it helps to only tighten the screws lightly at first and fully tighten them at the end.
- As for those small metal brackets IKEA provides: they’re usually sufficient, but if you want extra stability, replace them with higher-quality brackets from a hardware store. It doesn’t cost much and really makes a difference.
- A little fun tip: I like to use a small spirit level to make sure everything fits properly — even if it’s just a sideboard. That’s how I love my HEMNES, built solidly with a smile! 😄
I hope everything goes well and feel free to reach out if you hit any snags!
