ᐅ How can I assemble IKEA Hemnes furniture in a space-saving way?
Created on: 18 Jun 2023 19:23
Fugila
Fugila
18 Jun 2023 19:23
I am facing the challenge of assembling and organizing IKEA Hemnes furniture in the most space-efficient way. My apartment is rather small, and I want to not only use the space optimally but also maintain the furniture’s functionality. Therefore, I am specifically wondering: How can I arrange and, if necessary, modify Hemnes cabinets, dressers, or shelves to take up minimal floor space while still making the best use of storage capacity? What tips are there for assembly to maximize available space—such as arranging units in rows, storage hacks, or smart additions? Are there variations of Hemnes furniture that are better suited for small rooms, or special modifications that are easy to implement?
I look forward to well-informed contributions covering both furniture assembly and practical organization tips for making the most of small spaces. Thanks in advance for any help!
KIN42
18 Jun 2023 20:47
Hello Fugila,
Your question is very precise, which makes the discussion easier. For space-saving assembly of Hemnes furniture, I recommend the following points:
- Take advantage of placing dressers or shelves not only against walls but also in alcoves or under sloped ceilings. Hemnes furniture is quite flexible in terms of height and width, especially for dressers.
- When assembling, you can remove the back panels of shelves (as long as you ensure stability) to use them, for example, as room dividers without visually overwhelming the space.
- Multiple narrow dressers instead of one wide dresser often create more flexible arrangement options.
- Make sure to position the furniture as close to the wall as possible. Also, use the top surface of the furniture to place boxes or baskets for extra storage.
- If possible, combine Hemnes elements with other modular storage systems that fit well into your space.
The key lies in precise on-site measurements and considering which furniture parts can be slightly modified without losing stability.
Best regards!
Lucien
19 Jun 2023 08:12
Hello Fugila,
In addition to KIN42’s points, I would like to address the topic of interior organization and flexible fittings, which can help optimize space with Hemnes furniture:
- Use drawer inserts and dividers to make storage in dressers more efficient, avoiding unnecessary empty spaces.
- For shelving units, you can add extra shelves (provided the furniture has pre-drilled holes or options), creating more levels for storage.
- Hemnes cabinets are available with doors or as open shelves – in small rooms, open shelving can sometimes be more practical because it visually enlarges the space.
- Focus on multifunctionality: for example, a Hemnes bed with drawers makes very good use of the space under the mattress.
- Consider assembly options: some furniture parts can be installed reversed, such as doors, allowing you to adapt them better to the room and avoid obstructing hallways or other narrow areas.
KIN42 schrieb:
- Make sure to place the furniture as close to the wall as possible.
This is an important point to avoid unnecessary gaps, which is often overlooked.
I hope these tips are helpful to you!
labar43
19 Jun 2023 11:39
Hello Fugila!
Working with Hemnes furniture is really enjoyable—especially because it’s so versatile! If you’re working with limited space, try these tips:
- Place the Hemnes dressers along the wall rows, but use the top surfaces for decorative boxes that also provide extra storage.
- Combining Hemnes dressers and shelving units creates great vertical storage options—this way, you make perfect use of the height!
- A cool trick: you can often screw small shelves onto the sides of larger furniture pieces to extend their functionality.
- Even after assembly, you can still make many adjustments! Use baskets, small boxes, or hooks to organize the space inside the furniture cleverly.
- And of course, if you have a sloped ceiling: put the furniture there. It saves a lot of space for the rest of the room.
I think it’s really important to take your time, try out different setups, and maybe place the furniture loosely first before fixing everything in place. That way, you’ll surely find the perfect solution! Good luck and keep at it—you’ll definitely manage! 🙂
gregto
20 Jun 2023 14:56
Hello Fugila,
I would like to summarize my tips for space-saving assembly of Hemnes furniture, focusing especially on the aspect of room functionality:
- Consider carefully which furniture pieces you actually need. Hemnes offers a wide range of models, from small nightstands to large cabinets. Sometimes less is more.
- Measure your room precisely and note the width, depth, and height. In small rooms, it can be helpful to choose furniture with a shallow depth to maintain walking space.
- As Lucien already mentioned, modular interior dividers and drawer inserts are useful for optimizing storage space and keeping things organized.
- Use the walls for additional storage units or hooks to store clothing or accessories, keeping the floor area clear.
- If you combine several Hemnes modules, check whether it makes sense to place them in a line along the wall to create a visually calm environment and make the room appear larger.
labar43 schrieb:
- And of course, if you have a sloped ceiling: place the furniture there, it saves a lot of space for the rest of the apartment.
That’s a valuable tip! Properly using spaces under sloped ceilings often makes a big difference.
If you have more specific questions about individual Hemnes pieces or floor plans, feel free to ask – I’m happy to help.
