ᐅ How can I assemble the Ikea Brimnes furniture without using the instructions?
Created on: 31 Jan 2024 19:37
ricarda47R
ricarda4731 Jan 2024 19:37I am currently starting the project of assembling my new Ikea Brimnes wardrobe without using the included instruction manual. I have noticed that some furniture pieces could actually be put together quite intuitively if you understand their basic structure.
My specific question is: How can I systematically and as safely as possible assemble the Brimnes wardrobe without constantly referring to the detailed assembly instructions? What order of steps is recommended, what common pitfalls should I avoid, and which components should be connected first to create a stable foundation? I want to understand how the piece of furniture is designed as a whole, so I can approach the assembly efficiently.
Who has experience assembling the Brimnes without instructions and can share their tips and strategies?
Marcellela31 Jan 2024 20:12It is best to start by sorting all the parts and removing screws and wall plugs. Then, set up the side panels, insert the bottom panel, and attach the back panel. After that, assemble the doors and drawers. This way, you create a stable structure.
I can completely understand how stressful it can be to work without instructions. I felt the same way – at first, it’s easy to become overwhelmed. What helped me was taking it step by step and carefully examining each part before installation. The Brimnes is quite sturdily built, so don’t panic if something doesn’t fit right away. Just stay calm and take your time, and you’ll manage just fine!
Regarding the procedure: The Brimnes series is modular in design, starting with the two side panels. These form the basic framework, which is crucial for stability. Next, the bottom panels are attached, usually secured with dowels and cam locks. It is important not to install the back panel last, as it significantly contributes to reinforcement. The doors and drawers are only fitted at the end, since they would otherwise get in the way during assembly. As a general rule: build the main structure first, add the attachments last. This helps avoid common mistakes such as installing the back panel too early or assembling parts the wrong way around.
So, if you want to assemble the Brimnes without instructions, you’ll need a bit of patience and a good overall perspective. 😅 Tip: Think of the piece of furniture like a puzzle – start with the sturdy rectangle (sides and bottom), then the interesting back panel, which holds everything together like an invisible corset. 🕺 After that, the drawers come next; they’re like the fun little surprises at the end! From my experience, if you sort the screws and parts by size and proceed step by step, even assembling it 'without instructions' becomes enjoyable.
