ᐅ How can I assemble IKEA Brimnes furniture without drilling?
Created on: 26 Mar 2018 09:17
Celalettin
Celalettin
26 Mar 2018 09:17
Hello everyone, I am looking for a way to securely attach my IKEA Brimnes wardrobe to the wall without drilling. The reason is that I am renting and do not want to leave visible drill holes. The concern is specifically about the stability of the narrower wardrobes in this series, which can be somewhat prone to tipping over. Are there tried-and-tested methods or products that can be used as alternatives to the usual screw mounting? Perhaps adhesive solutions, special brackets, or furniture straps that do not require drilling? I would appreciate concrete tips, experiences, or even warnings, as I want to ensure long-term safety without undertaking major installations.
RABLA
26 Mar 2018 10:03
Use adhesive or self-adhesive wall mounts with high load capacity. Branded products designed for furniture attachment, commonly found in hardware stores, are recommended. Alternatively, there are anti-tip safety devices that clip on without the need for drilling.
Colby42
26 Mar 2018 11:28
Great question! I attached my Brimnes without drilling, using special brackets that are fixed to the wall with very strong mounting tape! It works really well, even if you don’t use the usual anchor/screw method 😊. Just make sure the adhesive sticks well to your wall material. Definitely give it a try—it saves you hassle with your landlord later and holds up nicely!
Dopoki
27 Mar 2018 08:45
For securely fixing the IKEA Brimnes without drilling, I recommend the following approach:
- Use special heavy-duty adhesive tapes (e.g., 3M VHB) that provide a permanent bond on smooth surfaces.
- Ensure the wall surface is completely free of dust and grease during preparation to achieve optimal adhesion.
- Additionally, anti-tip safety brackets can be installed, which secure the furniture to the wall using tension mechanisms, without drilling.
- Keep in mind that load-bearing and rough surfaces (e.g., textured wallpaper or tiles) significantly affect adhesion.
These methods avoid drill holes and provide sufficient hold but should always be checked regarding load and wall material.
LuMarcel43
27 Mar 2018 14:32
Dopoki schrieb:
Use specialized heavy-duty adhesive tapes (e.g., 3M VHB) that provide permanent adhesion to smooth surfaces.
This is certainly a sensible approach but should be considered with caution. Users often underestimate the load limits of adhesive tapes, especially with tall cabinets like Brimnes. Without mechanical fastening, there is always a risk of slipping or tipping, particularly when the cabinet is loaded. Therefore, I would recommend, especially in rental properties, to rely on temporary but mechanically secured solutions, such as modern clamp systems that are reversible.
A general recommendation for adhesive tapes can be risky here, as adhesion may change over time and with temperature fluctuations.
theo63
28 Mar 2018 10:56
LuMarcel43 schrieb:
Without mechanical fixing, there is always a risk of slipping or tipping, especially when the cabinet is loaded.
I agree with this. Especially furniture like the Brimnes, which is not very stable due to its construction, should be additionally secured against tipping. There are products that use strong hook-and-loop fasteners or rubberized mounts, but their hold is only satisfactory if the furniture is not overloaded.
An alternative are anti-tip straps, which can be attached residue-free using strong adhesive tapes. These are usually tightened with a ratchet system and provide mechanical securing without the need to drill. In my opinion, this is the best combination of safety and avoiding drilling.
One drawback could be that these solutions may not adhere permanently depending on the wall surface. Therefore, it is recommended to thoroughly check the substrate beforehand.
