ᐅ How do I build Ikea Besta drawers with dividers myself?
Created on: 28 Nov 2024 18:23
pomin
I am planning to equip an IKEA Besta shelving system with drawers and would like to divide the drawers into several compartments using custom-made dividers. My specific question is: What is the best way to build IKEA Besta drawer dividers yourself? Which materials are suitable, how do I measure the dividers precisely, and are there practical tips for securing the dividers firmly and accurately inside the drawer?
I don’t want to simply place loose dividers in the drawer; I want to create a clean, durable partition that won’t slide or rattle. I’m also curious whether it’s possible to use the IKEA measurements for the Besta drawers to prefabricate the dividers, or if I need to make custom cuts individually.
Any advice on tools, attachment methods, and experiences regarding stability and usability would be greatly appreciated.
Best regards!
pomin
29 Nov 2024 12:17
Domau0 schrieb:
Question for you: Are you planning horizontal or vertical compartments? Some options can also be realized with removable dividers.
Thanks for the detailed explanation! My idea is mainly to divide the drawers vertically into more open compartments, but some flexibility with removable dividers would definitely be useful. Right now, I’m unsure whether I should choose dado joints or another slotting solution because I don’t want to put in too much effort but still want a clean look.
Does anyone have experience with modular solutions that fit Besta drawers, where rails or guide systems can be installed to flexibly position dividers? Does this mainly require drilling, or are there alternative attachment methods?
blapau
29 Nov 2024 13:04
For flexible, removable dividers in Ikea Besta drawers, I can recommend systems based on rail strips. These are simply glued or screwed to the inside of the drawer sides, allowing individual dividers to be inserted.
It is important that the rail materials themselves are sturdy and that the dividers are made to fit precisely (with some allowance, of course). Some use narrow aluminum or plastic profiles, which are easy to cut to size.
If drilling is to be avoided, I consider high-adhesion adhesive pads possible, provided the surface is clean and smooth. However, screws usually ensure significantly better stability—especially under heavier loads.
This approach is mainly advantageous if you want to change the layout from time to time without cutting new pieces.
KAULIS
30 Nov 2024 07:29
A precise answer: IKEA does not offer official modular rails for Besta drawers. This means that third-party accessories or custom-made solutions are the alternatives.
A proven method, which can also be executed very neatly by hand, is using U-profiles made of aluminum or plastic, mounted on the sides of the drawer walls. The dividers with grooves or small pins can then be inserted into these profiles.
Useful tools include a drill, screwdriver, and file, in case adjustments are needed. For adhesive solutions, attention must be paid to load-bearing capacity and the surface condition of the drawer walls, as some painted finishes have poor adhesion.
In terms of quality and functionality, a fixed screw connection, even if slightly more complex, is the best long-term solution.
Filippo
30 Nov 2024 08:40
KAULIS schrieb:
In terms of quality and functionality, a fixed screwed connection, even if slightly more complex, is the best long-term solution.
I agree with that. Personally, my best solution follows these steps:
- First, carefully measure all interior walls
- Cut the partition walls precisely to the usable dimensions
- Drill small holes on the back of the drawer for countersunk screws
- Secure the partition walls with concealed connecting screws to ensure a clean appearance and stability
It is important not to set the screws too deep to avoid them pushing through the drawer front. Small felt spacers also prevent rattling noises.
I usually use plywood panels with a thickness of 8 mm (0.3 inches) because they offer a good balance between stability and ease of processing.
