ᐅ How can I assemble the Billy without drilling?
Created on: 24 Feb 2024 13:37
FOTAU
FOTAU
24 Feb 2024 13:37
Hello everyone, I want to assemble the Billy bookcase from IKEA, but I’m not allowed to drill holes in my apartment. My question is: How can I securely and firmly set up and fix the Billy bookcase to the wall without leaving any drill holes? I’m especially interested in tips on alternatives like adhesive mounts, tension rods, or other practical methods that won’t damage the wall. Has anyone had experience with these kinds of solutions and can explain the best way to do this? Thanks in advance for any detailed help!
todunar
24 Feb 2024 14:52
Great question, this issue affects many people who are not allowed to drill! 🙂 I have had very good experiences with so-called tension bars – these are clamped between the ceiling and the cabinet and hold the Billy shelf very securely. It is important that the ceiling is strong enough and that the bars are installed properly.
FOTAU schrieb:
How can I assemble the Billy shelf firmly and securely and attach it to the wall without leaving drill holes?
If you have curtain rods or tension rods, you can also use these as a top support and secure them to the shelf with brackets – sometimes this holds better than adhesive. Good luck, it’s great when you can manage something without drilling holes!!! :-)
Lorukeo
24 Feb 2024 16:07
The most important requirement for assembling a Billy-style shelf without drilling is stable surface pressure. The following methods are recommended:
1. Tension rods (also called tension strips, which connect the floor and ceiling)
2. Special adhesive or mounting putty that is strong and can be removed without residue
3. Attachment with hook-and-loop tape that has high adhesive strength
It is essential to know the maximum load capacity of the materials used, as the shelf may otherwise tip over or slip. Important: No solution is as secure as drilling and using wall plugs, but for light loads, tension or adhesive options work quite well.
todunar schrieb:
I have had really good experiences with so-called tension strips – they are clamped between the ceiling and the cabinet and hold the Billy shelf very firmly.
This is technically correct, although the installation must be done precisely. A ceiling height of 2.30 to 2.50 m (7 ft 7 in to 8 ft 2 in) is ideal to ensure enough tension.
FOTAU schrieb:
Alternatives like adhesive fastenings, tension devices, or other practical methods
Larger or more heavily loaded shelves are always more challenging, so please always pay close attention to the weight.
lubla
25 Feb 2024 09:21
I recommend tension rods for the ceiling. You simply clamp them between the floor and ceiling, and they hold well. Sometimes you can also try double-sided mounting tape, but that depends on the wall. There isn’t much more to say.
GALEO4
25 Feb 2024 11:42
I think this whole "no drilling" approach is often just unnecessary effort. Securing a Billy cabinet to the wall to prevent falls is not a trivial matter.
FOTAU schrieb:
How can I assemble the Billy cabinet firmly and securely and attach it to the wall without leaving drill holes?
If you really don’t want to make any holes, you might want to consider other types of furniture or at least accept that safety will be compromised. Tension rods or adhesives are more or less temporary solutions and can cause problems in the long run. I am skeptical about securing a heavy cabinet only by these means.
V
vin_leo
26 Feb 2024 08:55
Hey everyone :-)! Here’s what I did: I clamped tension rods to the ceiling (no drilling, no hassle) and placed the Billy bookshelf on top. Important: put non-slip mats on the shelf boards to prevent anything from sliding.
That’s absolutely right – 2.45 m (8 ft) works perfectly for me! And clamping strips are a really clever trick.
I decided against using glue because I was worried about residue on the wall. Good luck to you all, it will definitely work! 😉
