ᐅ How do I adjust IKEA PLATSA doors so that they close flush?
Created on: 25 Jan 2024 19:37
Klodian60
Klodian60
25 Jan 2024 19:37
Hello everyone, I have an issue with my IKEA Platsa wardrobe doors. The doors don’t close flush properly; sometimes they stick slightly or hang a bit crooked. I suspect it’s related to the door alignment and hinge adjustment, but I’m not entirely sure.
Could someone explain how to adjust the doors so they close cleanly and evenly? I’ve noticed that some hinges offer several adjustment options, but a step-by-step guide or practical tips would be really helpful!
Are there any specific features of PLATSA compared to other IKEA systems that I should be aware of? Thanks in advance for your support!
labar43
25 Jan 2024 20:14
Hey Klodian60, this sounds like the classic IKEA door alignment issue! But don’t worry, we can fix it! 😄
First of all: the PLATSA doors come with adjustable hinges that usually have three adjustment axes:
- Vertical (up/down)
- Horizontal (left/right)
- Depth (in/out)
This allows you to compensate for almost any irregularity! My recommendation: start with the vertical adjustment so both doors are level. Then adjust the horizontal setting to make sure the gap between the doors is even. Finally, adjust the depth so the doors close flush and don’t stick out too far either inward or outward.
It really helps to make small adjustments each time and test the doors frequently along the way. This way, you’ll reach the goal with less frustration! Good luck and don’t give up, it will turn out great! 👍
TEOZAR
26 Jan 2024 08:52
Hello Klodian60,
I would like to add something because many people underestimate the adjustment screws on PLATSA doors. The three main adjustment options are really important, and I’m happy to explain them in detail:
- The vertical screw is used to move the door up or down. This is useful for correcting uneven positions when doors are hung at different heights.
- The horizontal screw adjusts the distance between the door and the cabinet frame, controlling whether the door is recessed or protrudes—this plays a big role in achieving a flush closure.
- The depth adjustment ensures that the doors sit flat against each other or against the cabinet frame. This prevents sticking or unsightly gaps on the outside.
It is important to make the adjustments one after the other and not to overdo it; otherwise, the overall alignment will worsen. Sometimes it helps to briefly remove the doors and fully loosen all screws first to start from a neutral position.
I also recommend checking the condition of the hinges to see if they are damaged or bent, as this can make precise alignment difficult. If you have any further questions, I’m happy to help!
nubar
27 Jan 2024 13:25
TEOZAR schrieb:
It is important to make the adjustments one after the other and not to overdo it, otherwise the overall alignment will only get worse.
I think this is a very important point. To approach it more systematically, I would recommend adjusting each door individually until it is perfectly aligned before checking the overall appearance, as small irregularities can add up when dealing with multiple doors.
In addition, the attachment of the door panel to the hinge should always be checked: loosen the screws, adjust the door, then tighten the screws again.
Regarding specifics with PLATSA: unlike some other IKEA systems, PLATSA hinges often offer a somewhat larger adjustment range, which is helpful for uneven walls or cabinets. However, this also makes the adjustment process somewhat more complex if you are impatient. So take your time and make adjustments in small steps.
