ᐅ How can I align Ikea Besta doors to ensure they remain stable and straight over time?
Created on: 30 Aug 2021 19:22
Maandrei
Maandrei
30 Aug 2021 19:22
I’m currently adjusting the doors on my Ikea Besta cabinets and have noticed that after some time they no longer hang straight and feel somewhat unstable. My question is: What is the best way to align Ikea Besta doors so they remain stable and straight over time? I’m especially interested in setting the doors so they don’t become crooked or come loose with frequent use.
I have already adjusted the hinges, but that doesn’t seem to be enough. Are there any tips or specific steps to follow when making these adjustments? Do you need special tools? And how can you best check if a door is truly hanging straight?
I would really appreciate any experiences, tips, or detailed advice!
klo40
30 Aug 2021 20:11
Hello Maandrei,
I can help you with a step-by-step guide on how to properly align the Ikea Besta doors to ensure they remain stable over time.
1. Preparation:
- Make sure the cabinet frame is perfectly level. A crooked frame will inevitably cause the doors to hang unevenly.
- Check that all screws on the hinges are tight, but avoid overtightening them.
2. Door adjustment:
- Ikea Besta hinges typically have three adjustment screws:
- One for height adjustment (move the door up or down)
- One for side adjustment (move the door left or right)
- One for depth adjustment (move the door closer to or further from the cabinet frame)
3. Procedure:
- Start with the height adjustment to align the door exactly on the desired line.
- Next, adjust the side position so that the doors hang evenly without gaps.
- Finally, adjust the depth so the doors sit flush with the cabinet frame.
4. Check:
- Use a spirit level or a straight ruler to visually check the alignment.
- Open and close the doors several times to see if they rub or stick at any point.
5. Tips for stability:
- Readjust after a few days, as the doors may settle slightly.
- If hinge holes have loosened, consider reinforcing them with wood glue.
I hope this helps you with your project! If you want, I can also explain common mistakes and how to avoid them.
puvin
30 Aug 2021 21:03
Hey Maandrei! Great topic, I had the exact same problem with my Besta doors. What helped me a lot was:
- Patience when adjusting! The hinges are really sensitive.
- I got a small spirit level to work with millimeter precision.
- And very important: when tightening the screws on the hinges, do it gradually. Don’t tighten them fully right away, but step by step.
klo40 schrieb:
3. Procedure:
- Start with the height adjustment to align the door precisely with the desired line.
I can only confirm that, that’s exactly how I did it. In my experience, 2-3 rounds of checks after a few days bring the optimal stability. So just keep at it, it’s definitely worth it! Good luck!!!
Jonas66
31 Aug 2021 08:17
In short: Adjust the hinges in the correct order—first height, then lateral, and finally depth.
Important: The cabinet must be stable; otherwise, this adjustment is pointless.
Check with a spirit level; doors should not rub.
PEDRO40
31 Aug 2021 11:49
I completely understand how frustrating it can be when doors don’t hang perfectly straight, especially with Ikea cabinet doors, since you expect something simple. I spent months readjusting my doors repeatedly and can only say that it gradually gets better.
For me, it was important not to give up and to stay calm throughout the process. Maybe it will help you too if you don’t put too much pressure on yourself and make the adjustments step by step.
Maandrei schrieb:
Are there any tricks or specific sequences for adjustment? Do you need special tools?
I just bought a narrow spirit level that covers small parts, which helped a lot. Also, the sequence really matters – this proved true for me.
laume
31 Aug 2021 14:10
Hello Maandrei,
Thank you for your very well-formulated question! For many, adjusting the Ikea Besta doors seems more complicated than it actually is.
Here are some detailed tips for permanently aligning the doors:
- Before any adjustment, check if the cabinet carcass is level. Use a spirit level; if necessary, correct with small wooden wedges under the cabinet frame.
- Loosen the hinge screws slightly first, so you can adjust each axis individually.
- Avoid overtightening the hinges to prevent material deformation.
- Take a close look at the hinge mechanism – Besta hinges often have a rotary adjustment screw for lateral movement, which can be easily accessed with a Phillips screwdriver.
- Check the gap dimensions between the doors and between the door and the carcass to achieve even spacing.
- Take enough time to open and close the doors several times between adjustments.
If you follow these steps carefully, your doors will remain stable and straight in the long term. Good luck!
