ᐅ How do I adjust Ikea Besta doors and drawers to ensure they close perfectly?
Created on: 31 Dec 2023 08:37
farkla
Hello everyone, I recently assembled several Ikea Besta cabinets, and I’m having trouble aligning the doors and drawers perfectly so that they close cleanly and flush. Specifically, I want to install the doors without visible gaps and adjust the drawers so that they neither stick nor fit too loosely. What exact steps should I take to achieve a professional alignment? Are there any special techniques or tools I should consider when adjusting the Besta doors and drawers? Thanks in advance for your tips and experiences!
SONLIS
2 Jan 2024 09:58
In addition to the previous explanations, I would like to point out that Besta cabinets often allow for concealed hinge installation. It is important to adjust the screws with light pressure to avoid deforming the door material.
Precision is also crucial when aligning the drawer fronts, as small deviations become clearly visible across the entire furniture front.
My recommendation: Adjust the doors and drawers not only when installed but also before final assembly, then secure them carefully. This helps minimize complications.
nojaus
2 Jan 2024 15:22
Nabla64 schrieb:
Typical mistakes:
- Screws tightened too much, making adjustments difficult
- Furniture not fully assembled on a level surface
I can absolutely confirm that! I once had the problem that the floor was quite uneven, and I hadn’t considered that at all. The doors simply didn’t fit properly because the entire piece of furniture was rocking. So: Make sure the cabinet is really stable.
When it comes to screws, I often use a screwdriver instead of a cordless drill, as you have much better control when tightening. The adjustments for Besta are really minimal, and you don’t want to apply too much force to the screws.
