ᐅ How do I adjust Ikea Besta doors and drawers to ensure they close perfectly?
Created on: 31 Dec 2023 08:37
farkla
farkla
31 Dec 2023 08:37
Hello everyone, I recently assembled several Ikea Besta cabinets, and I’m having trouble aligning the doors and drawers perfectly so that they close cleanly and flush. Specifically, I want to install the doors without visible gaps and adjust the drawers so that they neither stick nor fit too loosely. What exact steps should I take to achieve a professional alignment? Are there any special techniques or tools I should consider when adjusting the Besta doors and drawers? Thanks in advance for your tips and experiences!
nojaus
31 Dec 2023 09:14
farkla schrieb:
I recently assembled several Ikea Besta cabinets, and somehow I can’t get the doors and drawers perfectly aligned so they close cleanly and flush.
I know that well, I also struggled quite a bit with my first Besta. The important thing is not to get stressed. For me, it helped to first loosely attach the doors, then adjust the hinge screws step by step. Sometimes you feel like a screwdriver surgeon, but patience pays off.
If the drawers stick, I always check whether they are really sitting straight in the runners. Often, just a small unevenness is the cause. If you want, I can also tell you the order of steps that worked best for me?
CHENFAR
31 Dec 2023 09:45
For perfect closing of Ikea Besta doors and drawers, I recommend the following structured approach:
- First, hang the doors on the hinges and then adjust them at three points: sideways for horizontal alignment, inward or outward for front alignment, and vertically for height.
- The screws on the cabinet hinges are generally designed for fine adjustments without removal.
- Drawers: Make sure the runners are correctly installed and parallel.
- Adjust the drawer fronts by turning a small screw mechanism on the drawer frame.
Tools: cordless drill with the appropriate bit, magnetic screw holder, spirit level for alignment.
A clean workspace and systematic approach will reduce the time needed to achieve the optimal result.
Nabla64
31 Dec 2023 10:29
Here is a brief step-by-step tutorial on how to properly align Ikea Besta doors and drawers:
1. Check the furniture hinges: They should be installed without tension – if necessary, slightly loosen all screws first and then carefully adjust.
2. Adjust sideways: The small adjustment screws on the hinges allow horizontal alignment so that the doors sit flush next to each other.
3. Align vertically: Typically, there is a screw on the hinges that lets you change the height of the door. This helps to even out height differences between doors.
4. Adjust depth: Another screw usually allows the door to be set deeper into the furniture or pulled outward.
5. Check the drawers: The running track is important; it should be free of play or sticking. The front panel is often adjustable with a small knurled wheel or screws on the side.
Common mistakes:
- Screws tightened too much, making adjustment difficult
- Furniture not installed on a completely level surface
If the doors still do not close properly despite alignment, check whether the furniture is positioned against the wall – sometimes adding a corner shim behind the case helps.
KINMIN4
31 Dec 2023 11:03
Door hinges:
- Adjust sideways, vertically, and in depth.
Drawers:
- Check the runners.
- Align the front using screws or adjustment rollers.
Proceed step by step.
juMira46
1 Jan 2024 14:11
CHENFAR schrieb:
A clean working environment and a systematic approach shorten the time needed to achieve the best result.
Absolutely! And once you’ve tightened the screws to properly fit the doors, it feels like a little DIY masterpiece. 😄 I find a good tip is to initially screw the doors in loosely and then tighten everything up at the end – this avoids unnecessary fiddling.
And don’t forget: A bit of humor always helps if a door doesn’t close perfectly right away. After all, it’s furniture assembly, not surgery.
