ᐅ How do I adjust IKEA Metod kitchen cabinets to fit my ceiling height?
Created on: 24 Jan 2019 08:37
Z
Zionix
Z
Zionix
24 Jan 2019 08:37
Hello everyone, I am currently planning to install an IKEA Metod kitchen in my apartment and have noticed that my ceiling height is about 275 cm (108 inches), which is significantly higher than the standard ceiling height. My question is quite specific: How can I adapt the IKEA Metod kitchen cabinets to such an unusually high ceiling without spending excessive money on custom-made units? Are there any proven tips or methods to modify or extend the carcase, base cabinet, or wall cabinet heights so that the space looks visually balanced and the storage functionality is maintained? I would appreciate advice, personal experiences, or practical suggestions, such as using extension frames, additional shelves, or similar solutions. Thank you in advance!
meGreg
24 Jan 2019 09:12
Zionix schrieb:
How can I adapt the IKEA Metod kitchen cabinets to such an unusually high ceiling without spending unnecessary money on custom-made units?
Hello, your question exactly matches what I planned a few years ago – except my ceiling was only 260 cm (8 ft 6 in). Back then, I found it great to work with so-called extension frames that IKEA offers as an addition to the cabinets. They are affordable, fit perfectly, and make the room feel much larger.
By visually adjusting the cabinet height with these frames, you can even try design variations, like open shelves on top. And don’t worry about it looking bulky. There are often very nice white or wood-colored frames that are unobtrusive.
You can picture it like this: Metod base cabinets at the bottom, extension frames, and then possibly a narrow tall cabinet on top – it fits great. So here’s a money-saving tip: check out the extension frames first, they really saved me a lot 😎
danial60
24 Jan 2019 11:45
The topic of ceiling height and IKEA Metod cabinets is really interesting and not as straightforward as many people think.
First of all, you should measure exactly how much space remains between the top edge of your selected wall cabinets and the ceiling. Metod wall cabinets typically have a standard height of 80 to 100 cm (31 to 39 inches), and you also need to account for the baseboard or a small gap behind the cabinets.
For ceiling heights like yours (275 cm / 108 inches), I recommend a combination of several steps:
- Use wall cabinets in the tallest standard size (e.g., 80 or 92 cm / 31 or 36 inches)
- Add filler panels (often 10–20 cm / 4–8 inches tall) on top of the cabinets to fill the gap
- Another option is additional decorative cover panels or sloped ceiling panels that can visually fill the space
Important: When installing, make sure the fixtures are strong enough, as taller filler sections have more weight and leverage. Use sturdy brackets and firmly attach the filler panels to the cabinets.
One final tip: If you want a seamless and high-quality finish, consider investing in a slightly customized trim as a top closure, which you can have made at IKEA or by a carpenter to measure. This way, the space up to the ceiling is perfectly filled without looking like an added piece stuck on.
If you like, you can share the measurements of your cabinets and the room, and I can offer more specific advice.
pikin
25 Jan 2019 07:52
danial60 schrieb:
For ceiling heights like yours (275 cm) I recommend a combination of several steps:
I agree and would like to add: The height of IKEA Metod kitchen cabinets is designed for standard ceiling heights of approximately 240 to 250 cm (94 to 98 inches). For rooms with higher ceilings, adjustments are necessary.
Key facts and approach:
- Wall cabinets are usually available in heights of 40, 60, 80, and up to 100 cm (16, 24, 31.5, and 39 inches)
- Extension frames (“filler panels”) come in 10 or 20 cm (4 or 8 inches) sizes and are used to adjust the height
- Base cabinet plinths are typically adjustable up to about 10 cm (4 inches), but this only levels the lowest part
- For very high ceilings (over 260 cm / 102 inches), a two-step approach can be used: taller wall cabinets (80–92 cm / 31.5–36 inches) plus extension frames plus possibly custom-made fillers
- All extension frames must be securely screwed to the cabinets below to ensure stability
Without these adjustments, kitchen cabinets may look out of place in tall rooms and the space planning can be inefficient, especially regarding storage capacity. You should also consider the impact on usability: for example, cabinets placed too high can be inconvenient in daily use.
Regarding costs, IKEA extension frames are an economical solution and can be effectively combined with custom-made fittings. Additionally, extra shelves or open shelving can help optimize storage space.
Laurence
26 Jan 2019 14:26
First of all, thank you for the detailed posts here! To add a summary from a practical, hands-on perspective:
- Measure the room height precisely before starting, including space taken by installations such as ventilation shafts
- IKEA Metod cabinets allow for height adjustment up to about 20 cm (8 inches) using the topper frames
- Alternatively, custom-made wooden panels can be used for the upper finishing zone, which can be matched to the wall color
- These panels are attached on top of the topper frames or upper cabinets and can, for example, be simple board elements
Please keep in mind that topper frames and panels must be securely screwed in to ensure safety when opening the doors and to maintain overall stability.
If you multiply your room height by the total height of the IKEA cabinets and add the topper frames, you will likely get very close to your target of 275 cm (108 inches). If you need a bit more height, additional panels or shelves make sense.
One more tip: It often looks good if the upper finishing panels are painted in the wall color or a shade that matches the countertop, creating a calm, high-quality effect.
If you like, feel free to share detailed measurements, and I can address your specific situation.
