ᐅ How can I adjust Ikea Besta furniture to fit room heights and window heights?
Created on: 22 Mar 2021 14:07
pekeo43Hello everyone,
I am planning to install Ikea Besta furniture in a room with an unusual ceiling height and relatively low windows. This raises the question: How can I best adjust the Besta units to the existing room heights and the window positions without making the furniture look bulky or out of place?
I would like to understand the options regarding furniture height, combining different modules, and possible modifications to ensure a harmonious use of the space. Are there proven methods to, for example, align the top edge of the cabinets just below the windowsill or to other room heights?
I am also interested in tips for visual balance when windows and furniture are not perfectly aligned, and whether there are specific accessories or installation options that should be considered.
I would appreciate any experience reports or technical advice to adapt the Besta system as effectively as possible to these unique room conditions.
I think many people overthink adapting IKEA furniture to unusual ceiling heights. After all, it’s a modular system, so flexibility should not be a problem—right?
But honestly: If you adjust everything perfectly to window and ceiling height, it can quickly come across as flashy or even uninspired. Sometimes it’s better to deliberately create contrasting lines that highlight the furniture piece as a standalone design object.
Personally, I wouldn’t put anything “under the windowsill,” but rather work with open compartments above window height to create an interesting break. This goes against the traditional idea of custom-built furniture but adds more dynamics to the room.
pekeo43 schrieb:
How can I best adapt the Besta units to the existing ceiling heights and window positions without the furniture looking bulky or out of place?
I would recommend adjusting the Besta units by using adjustable feet and appropriate cover plates. These allow for flexible height adjustment and can compensate for slight height differences.
Regarding the windows: installation below the windowsill is possible if the furniture modules are shortened or built accordingly. Although Ikea does not offer direct cutting services for this, it can be done with some DIY skills.
Additionally, visually it works better if the furniture color selection is coordinated with the wall and window frame colors.
Regarding the question of how to adapt Ikea Besta furniture to unusual room and window heights, I recommend a clear, structured approach:
- First, measure the exact room and window dimensions in detail, including the windowsill height and ceiling height.
- Besta modules are generally 38 cm (15 inches) deep and come in different heights (e.g., 38, 64, 128 cm (15, 25, 50 inches)). Combine these to achieve the appropriate total height.
- For low windowsills, a combination of lower base cabinets plus an open shelf or shelves mounted below the windowsill can be used to precisely match the height.
- To visually coordinate the furniture with the window frames, additional baseboards or panels that reflect the colors and shapes can be added.
- If shortening the carcasses is necessary, they must be cut accordingly; this is advisable for wood or MDF with a durable surface finish.
In general, it is recommended to plan the exact configuration with Ikea’s planning tools before purchasing and, if uncertain, to place individual modules in the room temporarily for testing.
I can fully understand the effort and concerns involved in working with Ikea Besta furniture in rooms with unusual proportions.
That’s a good point, but also make sure the furniture doesn’t appear out of place. In my case, I noticed that despite varying heights and window sill heights, you can achieve a harmonious overall look by carefully choosing matching colors and materials.
If the furniture needs to fit under the window sill, I used small intermediate blocks and spacers to precisely position the furniture without affecting its functionality.
My experience: It takes some courage to create custom solutions that work with the given dimensions. But the effort is worthwhile — in the end, you create an atmosphere that fits well and is enjoyable.
Gilbert schrieb:
Sometimes it is better to intentionally create contrasting lines that emphasize the piece of furniture as an independent design element.
