ᐅ How can I achieve perfect alignment for a Pax wardrobe door?
Created on: 22 Jan 2024 19:23
Z
Zosimusga
Z
Zosimusga
22 Jan 2024 19:23
Hello everyone, I am currently working on perfectly aligning my IKEA Pax door but keep running into issues with precise adjustment. My question is: How can I achieve a perfect Pax door alignment so that the doors open and close smoothly without rubbing against each other or the frame, or getting stuck? I am especially interested in tips and tricks for fine-tuning the hinges, using a level or other tools, as well as advice on common pitfalls to avoid. I have already followed the standard instructions, but they don’t fully help with the exact adjustment. I’m looking forward to your helpful suggestions!
narDietmar
22 Jan 2024 20:08
The perfect alignment of the Pax door actually starts with thorough preparation. It is important to first slightly loosen all the hinge screws so the door can still move. Then, it is advisable to roughly align the door before beginning to adjust the hinges step by step. Use a spirit level to ensure the doors hang horizontally – both at the top and the bottom. It is often helpful to correct the vertical position first, as a slight deviation here can quickly cause rubbing issues at the bottom of the cabinet. The hinges usually have multiple adjustment screws: - height, - depth, - lateral position. The lateral adjustment is often the key to achieving perfect gap widths. If the doors still stick, the lower area is often the cause, where the hinges sometimes rub against the inside frame. I recommend making only small adjustments at a time and checking repeatedly how the door closes in between. This way, you can gradually eliminate possible errors.
Dopoki
23 Jan 2024 07:41
narDietmar schrieb:
The perfect alignment of the Pax door actually begins with thorough preparation.
Absolutely, a structured approach is essential. Additionally, when working with the Pax door, it is important to ensure the hinges match the specific model, as different generations of IKEA hinges have slight design variations that can affect adjustment.
Furthermore, it is advisable to position the cabinet as precisely vertical as possible. Most door alignment issues arise from a slightly tilted installation wall or an uneven floor. If in doubt, check with a precise level—preferably a digital one or a spirit level capable of measuring on multiple planes.
For fine-tuning the hinges, adjust the screws in the following order:
- first the height,
- then the lateral alignment,
- and finally the depth.
This sequence prevents continuous readjustment. When closing, pay attention to the gap measurements: a 2–3 mm (approximately 0.08–0.12 inches) space between doors is ideal. Avoid exceeding this gap to prevent the door from sticking during use.
Z
Zosimusga
23 Jan 2024 13:56
Dopoki schrieb:
When in doubt, check with an accurate spirit level (preferably digital or with bubble levels on multiple axes).
Thanks for the advice! I actually suspect that my cabinet frame is slightly out of level, which then causes the main issues.
narDietmar schrieb:
The hinges usually have several adjustment screws: - height, - depth, - lateral position.
Could you please explain in more detail which screw affects which adjustment? For example, which screw specifically controls the height, and how can I tell during the adjustment that this particular screw still needs to be turned?
I would like to avoid turning multiple screws every time and then having to readjust everything. Are there any tools or aids beyond standard tools that you would recommend for making these adjustments?
I am also interested in your thoughts on narrow gap widths between two doors – how tight should they be without sticking or touching?
PeoDaniel
24 Jan 2024 09:34
Zosimusga schrieb:
Could you maybe explain a bit more precisely what effect each screw has?
Of course, I’ll try to explain as clearly as possible:
- The “height” screw is usually the one that allows you to adjust the door vertically, meaning up or down. It’s often located on the hinge arm, which you can detach from the cabinet body and slide, or it’s adjusted via a special screw. If the door sticks or doesn’t close flush at the top or bottom edge, this screw is the right adjustment point.
- The “lateral” screw controls shifting the door closer to or further from the cabinet body side to side. Use this if the gaps between doors or between the door and cabinet are uneven. It ensures the door stands parallel to the cabinet.
- The “depth” screw is for fine-tuning the distance of the door from the cabinet body, in other words whether the door sticks out or sits recessed. This is important if the door rubs anywhere on the cabinet.
A good Phillips screwdriver with a fine tip is helpful for most hinges to adjust the screws precisely. Some users also use a small square or a gauge to better visually assess the gap sizes.
Zosimusga schrieb:
I’m also curious about your opinions on narrow gaps between two doors – how tight should they be without sticking or touching?
Ideally, the gap should be about 2 to 3 mm (0.08 to 0.12 inches). Less than that may cause rubbing, while more than 3 mm (0.12 inches) makes the cabinet appear less premium.
