ᐅ How different are the materials used in the various Ikea BRIMNES furniture pieces?
Created on: 10 Jan 2020 08:37
Firuren
Firuren
10 Jan 2020 08:37
I am currently looking into the different Brimnes furniture pieces from Ikea and wondering how much the materials used vary across the different items in this series. There are wardrobes, dressers, beds, and shelves – but I am not sure whether Ikea uses the same materials consistently throughout or if the material composition differs significantly depending on the furniture type and intended use. I am interested in both the surface finishes, such as laminates or paint coatings, and the core materials (for example, engineered wood, MDF, particleboard, etc.) as well as their quality and any differences in stability. If anyone has detailed information about the material mix or experience regarding the durability and robustness of the individual furniture pieces, I would be very grateful for a thorough breakdown. Thanks in advance!
Wyatt
10 Jan 2020 09:42
Hello Firuren,
your question is really interesting, and as you correctly assume, the materials used in the BRIMNES furniture vary significantly depending on the type and intended use. In general, Ikea mainly uses engineered wood products in this series, primarily high-density fiberboard (HDF), medium-density fiberboard (MDF), and particleboard, but in different combinations.
For example, the carcasses of cabinets and dressers are often made of particleboard because it is cost-effective and sufficiently stable for indoor loads. The fronts, on the other hand, are often made of MDF, which allows for a smoother surface, ideal for painting or laminate coverings. The surfaces of BRIMNES furniture are usually melamine-coated or covered with plastic foil, making the furniture quite scratch-resistant and easy to maintain, but often at the expense of a natural feel.
Beds from the BRIMNES range, meanwhile, partially use stronger frame constructions made from HDF or even solid wood components to withstand higher loads. The back panels tend to be thinner and less robust. Regarding durability, you should especially pay attention to the support structures and drawer slides (metal runners vs. simple plastic glides), as the quality varies here.
I would be interested to know which specific furniture type you are focusing on, as the material appearance and quality vary greatly. Depending on the use and room, it might make a difference whether, for example, a dresser is best suited for the bedroom or a cabinet for the hallway.
Are there particular pieces from the series you would like to focus on for the material analysis?
TRA33
10 Jan 2020 10:03
The BRIMNES furniture is mainly made of particleboard with MDF fronts, all featuring a melamine-coated surface. The beds are built somewhat sturdier, but the basic material remains similar.
nera59
10 Jan 2020 11:28
Additional information:
- Carcasses: Usually particleboard (about 12-16 mm), an affordable and sturdy base
- Fronts: MDF, mostly with a white or foil finish, suitable for smooth surfaces
- Surfaces: Melamine resin coating or foil, resistant to moisture and scratches
Common issues with BRIMNES often include overloading individual shelves, as particleboard can sag over time even under moderate use. I recommend not overburdening the shelves and paying attention to the joints on the beds, as these are frequently weak points in terms of stability.
If you like, I can also provide a brief overview of care tips and typical weaknesses for the individual pieces of furniture in this series.
Firuren
10 Jan 2020 13:11
Wyatt schrieb:
I’m interested in knowing which type of furniture you have in mind, as the material appearance and quality vary greatly depending on that.
Thanks, Wyatt, very helpful overview! I’m particularly interested in the BRIMNES dressers and wardrobes, as I’m currently considering replacing my old storage furniture. My focus is on long-term durability and surface quality because I tend to rearrange my furniture quite regularly and sometimes have some weight in the drawers.
It would also be interesting to know if the different material choices between the dressers and wardrobes significantly affect stability or overall robustness. Is it true that wardrobes often have thinner or fewer back panels? Or are they comparable in this case?
The point about shelves and load-bearing capacity makes sense. Are there differences between the BRIMNES variants, for example in shelf thickness or the drawer systems?
Wyatt
11 Jan 2020 07:56
Firuren schrieb:
I am mainly interested in the BRIMNES dressers and cabinets, as I am currently thinking about replacing my old storage.
For dressers and cabinets, Ikea generally uses particleboard with a thickness between 12 and 16 mm (0.5 and 0.6 inches) for BRIMNES, while the corresponding MDF fronts are usually about 16 mm (0.6 inches) thick. The back panels of cabinets are typically thinner (around 3 mm (0.1 inch) hardboard) since they mainly serve as stabilization rather than a load-bearing element. Dressers may have back panels of the same thickness, but this depends on the specific model.
The drawer systems in BRIMNES use basic metal drawer slides that are sufficient for normal use. They are not comparable to more expensive soft-close mechanisms but hold up well depending on usage. The shelves in both furniture types are usually of the same thickness and interchangeable, although I would recommend not exceeding a maximum load capacity of about 10-15 kg (22-33 lbs) per shelf.
The difference in stability mostly comes from the construction method and the interaction between the carcass, back panel, and fasteners rather than from the basic materials. If you expect to move the furniture frequently or require more durability, you can consider the following:
- Secure the back panels additionally (e.g., with better screws or brackets)
- Look for shelves with additional support braces
- Avoid overloading drawers and upgrade the slides if needed
If you need more technical details, feel free to ask.
