ᐅ How affordable can hardwood flooring be?
Created on: 26 Feb 2017 23:28
Mizit
we purchased a 20-year-old house that still has the original laminate flooring installed in the upper floor.
At first, we planned to install laminate there again, but now we are leaning more towards hardwood flooring. A carpenter friend advised us: better to choose inexpensive hardwood than expensive laminate flooring.
We are not yet 100% decided. Our requirements are:
- There is no underfloor heating, and due to previous troublesome experiences, we definitely will not install it.
- The laminate was installed as a floating floor.
- We have two small children who will remain quite young for the next 10 years, so the floor will certainly be subjected to some wear and tear.
Initially, our thought was to install relatively inexpensive laminate, around 15 euros per square meter (about 1.40 USD per square foot), and consider hardwood in 10 years.
We no longer find this very sensible. Hardwood clearly looks better visually and is probably more comfortable to walk on. Also, while solid or engineered hardwood can be sanded and refinished after several years, this is not possible with laminate, which means removing and replacing the entire floor again.
At first, we assumed hardwood flooring would not be available for less than 80 euros per square meter (about 7.40 USD per square foot). However, we found offers for engineered hardwood at around 45 euros per square meter (about 4.15 USD per square foot) in a local store. Some online shops even offer it cheaper.
We are not looking for the cheapest option at any cost. For now, our budget for initial repairs is limited, so it’s a matter of weighing the options. If we were to spend 15-20 euros per square meter on laminate, it makes more sense to invest 40-50 euros per square meter in hardwood, which will provide better living quality, appearance, value, and durability.
However, if engineered hardwood at 40-50 euros per square meter is poor quality, this calculation doesn’t hold; but we currently cannot budget 100 euros per square meter for hardwood.
We are not fixed on a particular type of wood; both plank flooring and strip flooring appeal to us aesthetically. The product does not need to be premium eco-friendly, but we do not want a floor with strong formaldehyde emissions, especially in the children’s rooms. Also, the floor should have a wear layer thick enough to allow at least one sanding and refinishing.
Mizit
21 Mar 2017 13:42
Yes, but for 20 m² (215 sq ft)...
RobsonMKK21 Mar 2017 13:51
If there is not much breaking up required, it does not make a significant difference.
Nordlys
21 Mar 2017 14:38
Calculate 50 per square meter installed net, so plus tax. Material installed. 28 for the material, 22 for the installation. As a student, I worked in an installation crew and earned good hourly wages in 1980. It definitely won’t take more than 12 hours. The bonding goes quickly. But you also pay a flat rate that includes travel time and downtime for the workers.
Mizit
22 Mar 2017 22:20
28 euros per square meter for parquet flooring? Isn’t that extremely low for the material cost?
Nordlys
22 Mar 2017 22:46
Didn’t you mention 28 earlier? Or did I misread it?
daniels87
27 Mar 2017 13:01
We installed parquet flooring in the bedroom and dressing room for about €27 per square meter (around $27 per square yard). It’s rustic knotty oak, brushed and oiled. I’m glad we didn’t choose laminate or vinyl, as this is a completely different experience. The gluing process itself isn’t complicated—I had never done it before. However, the subfloor really needs to be thoroughly prepared. I neglected this a bit, which caused a hollow spot. Luckily, the bed is positioned over that area.
