ᐅ How affordable can hardwood flooring be?
Created on: 26 Feb 2017 23:28
Mizit
we purchased a 20-year-old house that still has the original laminate flooring installed in the upper floor.
At first, we planned to install laminate there again, but now we are leaning more towards hardwood flooring. A carpenter friend advised us: better to choose inexpensive hardwood than expensive laminate flooring.
We are not yet 100% decided. Our requirements are:
- There is no underfloor heating, and due to previous troublesome experiences, we definitely will not install it.
- The laminate was installed as a floating floor.
- We have two small children who will remain quite young for the next 10 years, so the floor will certainly be subjected to some wear and tear.
Initially, our thought was to install relatively inexpensive laminate, around 15 euros per square meter (about 1.40 USD per square foot), and consider hardwood in 10 years.
We no longer find this very sensible. Hardwood clearly looks better visually and is probably more comfortable to walk on. Also, while solid or engineered hardwood can be sanded and refinished after several years, this is not possible with laminate, which means removing and replacing the entire floor again.
At first, we assumed hardwood flooring would not be available for less than 80 euros per square meter (about 7.40 USD per square foot). However, we found offers for engineered hardwood at around 45 euros per square meter (about 4.15 USD per square foot) in a local store. Some online shops even offer it cheaper.
We are not looking for the cheapest option at any cost. For now, our budget for initial repairs is limited, so it’s a matter of weighing the options. If we were to spend 15-20 euros per square meter on laminate, it makes more sense to invest 40-50 euros per square meter in hardwood, which will provide better living quality, appearance, value, and durability.
However, if engineered hardwood at 40-50 euros per square meter is poor quality, this calculation doesn’t hold; but we currently cannot budget 100 euros per square meter for hardwood.
We are not fixed on a particular type of wood; both plank flooring and strip flooring appeal to us aesthetically. The product does not need to be premium eco-friendly, but we do not want a floor with strong formaldehyde emissions, especially in the children’s rooms. Also, the floor should have a wear layer thick enough to allow at least one sanding and refinishing.
Mizit
19 Mar 2017 20:45
And one more question for the experts: Does glueing (by a professional) take significantly longer than a clip system? How much time would you roughly estimate for 50 sqm (540 sq ft)?
Also, does glueing make sense if the parquet is rather low budget?
RobsonMKK19 Mar 2017 20:57
It depends on whether the room is irregularly shaped. The actual installation shouldn’t take much more than one day. But why? It is usually calculated per square meter (square foot), not by hours.
Mizit
19 Mar 2017 22:16
No, there’s nothing particularly complicated or convoluted about it.
RobsonMKK20 Mar 2017 06:34
Here is how it went for us:
Day 1: Sand the room and apply leveling compound
Day 2: Install parquet flooring (about 20 sqm (215 sq ft))
Day 3: Oil the entire floor
However, he was only there for a few hours each day.
For installing across 50 sqm (538 sq ft), it should go quickly.
Mizit
21 Mar 2017 13:16
We want to use prefinished hardwood flooring. So, no oiling should be necessary. I’m not sure about the leveling compound... There is an impact sound insulation layer underneath, which would probably have to be removed if the floor is glued down. But is an estimated 20-25 hours of professional work for just under 50 m² (540 sq ft) roughly realistic, or are we likely to go well beyond that?
RobsonMKK21 Mar 2017 13:28
I would consider that the absolute maximum. For us, it was a total of about 12 hours.
