Mojtaba6610 Jan 2021 19:37Hello everyone, I am currently planning to modify and upgrade my IKEA Besta system as a base for a workbench in my hobby workshop. I am wondering how to best stabilize and functionally expand the Besta so that it can withstand the stresses of screwing, sawing, and other workshop tasks. Specifically, I am interested in which additional materials or reinforcements are useful, how to make the work surface durable, and which practical additions like drawers or tool holders can be implemented without major changes to the basic frame. Does anyone have experience or clever tips on how to upgrade a Besta specifically for a workbench without the structure tipping over or becoming too unstable? What attachment options are available for additional worktops or mounts? I look forward to detailed suggestions and personal experiences from you.
Good evening, for upgrading an IKEA Besta system into a workbench, I recommend the following points:
- Stabilize by adding a sturdy back panel made of plywood or OSB boards, screwed to the inner edges of the Besta frame.
- Use a thick, durable worktop (at least 3 cm (1.2 inches) thick) made of plywood or beech wood, which can be mounted directly on top of the Besta using flat dowels or screws.
- To increase stability, you can also screw angle brackets between the bottom panel and the carcass.
- Perforated panels are suitable for tool holders and can be attached to the side or front of the carcass.
- Drawers with full extension runners can be enhanced with additional sturdy inserts, but be mindful of the maximum load capacity of the runners.
- It is advisable to replace or add height-adjustable furniture feet made of plastic or metal to compensate for uneven floors.
These measures ensure a stable and functional workbench base with solid load-bearing capacity.
Hello, I would like to add that when converting the Besta into a workbench, the weight and load of the tools are very important. If your worktop is made of heavier materials like stone or metal, it would be advisable to install cross braces made of wood or metal underneath to better distribute the weight. Securing the Besta to the wall also greatly increases safety in case the workbench is subjected to too much pulling or pressure.
This tip is very helpful. I would also recommend reinforcing the entire structure with suitable screws and pre-drilled holes to prevent deformation. If you plan to install drawer inserts, it is useful to customize the interior with homemade dividers or organization systems to prevent tools from sliding around.
If you like, I can also provide you with instructions on the best way to do this.
BEMAU schrieb:
To increase stability, corner brackets can also be screwed between the floor and the cabinet.
Torsten4511 Jan 2021 10:52The main weakness when using the IKEA Besta as a workbench base is its stability against tipping movements and point loads during work. Therefore, I recommend:
- Securing the worktop with at least four sturdy screws on each cabinet.
- Using metal profiles or brackets to connect the cabinets underneath, preventing twisting.
- Installing height-adjustable, non-slip legs at the corners for leveling.
- Reinforcing the side panels with plywood sheets instead of just thin particleboard.
With these reinforcements, you get a solid base that will hold up even under heavy loads. Also, make sure that the drawer slides are rated for the required load—consider strengthened versions or fully extending drawers if needed.
