ᐅ How can you tell if a BILLY shelf is properly aligned?
Created on: 7 May 2023 08:13
NUFUSAN
Hello everyone, I recently got a Billy bookcase from Ikea and want to make sure it is properly aligned. My specific question is: How can you tell if a Billy bookcase is straight and correctly positioned, especially when you don’t have professional tools at hand? What exactly should you pay attention to, which simple tools might help, and what are common mistakes to avoid when aligning it? I want the bookcase to be both visually appealing and functionally stable. Thanks in advance for your tips!
NUFUSAN
7 May 2023 13:02
Thank you for the detailed answers! To summarize:
- Use a spirit level (or an app) to check vertical and horizontal alignment
- Use furniture shims or felt pads to compensate for uneven floors
- Secure the shelf to the wall (using appropriate wall plugs)
- Perform a visual check from different angles
- Monitor over time to see if the shelf settles or wobbles
One last question: Are there differences between BILLY shelf models that make leveling more difficult or easier? For example, the narrower versions or different back panels?
Palenar
7 May 2023 13:28
NUFUSAN schrieb:
Are there differences between BILLY shelving models that make leveling easier or more difficult?
Yes, definitely! The classic BILLY shelves with sturdy back panels (usually MDF, often in white or brown) are a bit more robust and help with leveling since they provide additional stability to the shelf. In contrast, the narrower models or those with less stable back panels (back panel made only of thin HDF cardboard) tend to be more flexible and are more challenging to level on uneven floors or when attaching to walls.
Height also plays a role: taller shelves definitely require wall mounting, as they are more prone to tipping, and even small deviations become more noticeable.
If you are attaching the shelf to a wall that is not completely smooth (e.g., uneven plaster), using wall spacers or additional shimming with wedges can help.
nonpra
7 May 2023 13:45
Narrower models are more sensitive to misalignment. Therefore, wall mounting is even more important.
Peose
8 May 2023 07:58
Good morning everyone! 🙂 I just wanted to emphasize again how much proper alignment affects the overall feel! When the shelf is positioned correctly, the entire room looks so much more harmonious!
So don’t get discouraged if it’s not perfect the first time – sticking with it and patiently adjusting really pays off. Looking forward to your next successes with BILLY shelves! 🙂
