ᐅ How can Ikea Besta doors be replaced?
Created on: 2 May 2020 08:23
mene51
mene51
2 May 2020 08:23
Hello everyone, I have a specific question about replacing doors on an Ikea Besta shelving unit: What is the easiest and safest way to replace the doors of the Ikea Besta series without damaging the furniture or affecting the functionality of the hinges? I have already tried to remove the existing doors but haven’t been able to figure out exactly how to properly detach the hinges or whether there are special tools that make this easier. I am also interested in whether new doors, possibly in a different color, can be installed without issues after removing the original ones, and what steps should be taken to prepare the mounting. Has anyone had practical experience or can provide a clear step-by-step guide? Thanks in advance!
DUVIN
2 May 2020 09:07
The doors on Ikea Besta are attached with clip hinges. To remove the door, open it, locate the small levers on the hinges, carefully pull them out, and then you can take the door off. For installing new doors, simply attach the clip hinge mechanism to the door and then snap it into place. Normally, you don’t need any tools, except maybe a screwdriver if some adjustments are required.
REPITAR
2 May 2020 13:02
DUVIN schrieb:
The doors on Ikea Besta units are attached with clip hinges.
That is correct, and I would like to add a brief guide:
- Fully open the Besta door so you have clear access to the hinges.
- Each hinge has small plastic levers that you can press parallel to the hinge to release the door.
- Pry gently to avoid damaging the hinges.
- Make sure the hinges remain attached to the cabinet frame, as this makes rehanging the door much easier later on.
- To install a new door, first attach the hinges to the door (usually with screws), then hang the door onto the cabinet frame and snap the clips into place.
Common mistakes include pulling the door panel too roughly or twisting the hinges, which can cause alignment issues. If you want to install doors that are not from Ikea, check whether the mounting holes match or if you need to drill new ones.
pilous
3 May 2020 19:48
I wonder: Is replacing the doors really as straightforward as it is often presented? On the Ikea forum, you occasionally read about people having problems with the fit of new doors, especially when they come from other manufacturers or have slightly different dimensions.
REPITAR schrieb:
If you want to install doors that are not from Ikea, you should check whether the mounting holes fit or if re-drilling is necessary.
I consider this a critical point that deserves more attention. Additionally, how durable are the clips with frequent door changes? Are there any experience reports regarding wear and tear? It would also be interesting to know how well the hinges can be adjusted if the doors do not fit precisely.
Matthewt48
5 May 2020 11:36
pilous schrieb:
In the Ikea forum, you occasionally read about people having issues with the fit of new doors
That’s a very good point, which I’d like to add to: Ikea Besta doors are standardized, and the optional adjustments on the hinges allow you to compensate for small discrepancies. Here are some important details to keep in mind:
- The hinges allow for fine horizontal and vertical adjustments (usually with a Phillips screwdriver) to correct fitting inaccuracies.
- When installing for the first time, make sure the door aligns flush with the cabinet frame and that no gaps appear.
- If you are using Ikea doors, replacement is really easy and durable. With other doors, adjustments may be necessary, such as repositioning drill holes or refinishing the surface.
I also recommend searching for Ikea’s installation guide for Besta doors as a PDF – it clearly shows the adjustment options. This helps you understand the mechanism and avoid frequent readjustments.
If you’re unsure whether you’re doing everything correctly, feel free to ask more questions!
