ᐅ How can you repair damage to Ikea Hemnes furniture yourself?
Created on: 21 Apr 2020 10:23
jackon
jackon
21 Apr 2020 10:23
I have a specific question about DIY repairs for Ikea Hemnes furniture. On my Hemnes sideboard, the surface has started to peel in several places due to moisture, and at one corner, a drawer has come off its track because one of the metal runners is bent. Since Ikea doesn’t always provide spare parts for older models or can be difficult to reach, I’d like to know the best way to repair these kinds of damages myself without compromising the appearance or stability.
I’m especially interested in which materials are suitable for restoring the surface finish or concealing scratches, and whether there are effective methods to straighten or replace bent metal runners.
I look forward to tips on tools, suitable adhesives or paints, and step-by-step instructions, if available. Thanks in advance!
plo60
21 Apr 2020 14:48
jackon schrieb:
The surface of a Hemnes sideboard has come loose in several places due to moisture, and in one corner a drawer slipped off its track because one of the metal runners is bent.
This sounds like a typical case of material failure in furniture with a wooden core and veneer. I would first consider whether the moisture damage is localized or if there is a general problem with indoor humidity, as even the best repair won’t help if the root cause isn’t addressed.
Regarding the surfaces, repair kits with wood filler and color-matched wood touch-up markers are often the best option—but they do not replace a full refinishing. In this case, it is important to realistically assess whether the piece remains visually acceptable or if it would be better to invest in a replacement.
For the metal runners: bent slides can often be carefully reshaped using pliers, taking care to avoid sudden bending or breaking—they are usually made of spring steel that is somewhat flexible. If you need replacement parts, compatible drawer runners from other manufacturers often work well. Have you checked whether Ikea sells the metal runners separately? I think it’s worth clarifying this first.
kibutar
22 Apr 2020 09:17
For surface repair of your Hemnes sideboard: The finish is usually made of painted or veneered solid wood, which can easily swell or delaminate when exposed to moisture. A lasting repair requires a careful approach to avoid further damage.
1. Clean the surface and let it dry – this is the basic step.
2. For peeled veneer: Small detached spots can be carefully glued back with wood glue, place thin paper underneath any gaps, then press.
3. For scratches in the paint, special furniture repair fillers or color markers from a woodworking supplier can be helpful. Make sure to match the color tone and gloss level exactly, which takes patience.
4. For severely warped or damaged areas, sanding and repainting is worthwhile, but this requires professional knowledge to match the color and sealing.
Regarding the drawer slides:
- It is best to carefully bend metal slides back into shape using a sturdy round-nose plier or small vice. Work gently, as the material is thicker metal and breaks easily.
- If you want to replace the slides, Ikea sells some spare parts, though they often need to be ordered through customer service.
- Alternatively, universal drawer slides can be used, which you can cut and install yourself – however, this often changes the installation.
Pay special attention to the following:
- When repairing yourself, also check that screws and connectors are not damaged, as these are often weak points in older Hemnes furniture.
- I wonder how old the sideboard is, to be able to assess material fatigue – have you considered that?
rubybi
23 Apr 2020 16:02
Here is a brief guide for DIY repairs on Ikea Hemnes furniture, specifically addressing surface damage and drawer slides:
Introduction:
- Hemnes furniture is usually made of solid pine with lacquered or stained finishes. Damage often occurs due to moisture or mechanical stress.
Surface Repair Step-by-Step:
- Step 1: Remove any coverings, gently clean the furniture, and allow it to dry completely.
- Step 2: Carefully apply wood glue to any delaminated veneer areas, insert very thin paper, and clamp the parts together.
- Step 3: Touch up small scratches using color-matched wax sticks or repair fillers.
- Step 4: For larger surface damage, lightly sand the area (fine sandpaper, grit 240+) and apply a matte clear varnish to restore color and protection.
Drawer Slide Repair:
- Bent metal slides are usually thin steel sheet profiles. Gently reshape them with pliers, taking care to avoid breaking.
- If the slides are stretched out or unusable, it is better to buy complete replacements from a hardware store and adapt them as needed.
Summary:
These methods are common and generally effective, provided the material is not severely damaged by moisture. If you like, I can also recommend specific products.
One more question: How deep is the surface damage? Just superficial bubbles or actual delamination?
lochen
24 Apr 2020 08:45
kibutar schrieb:
I wonder how old the sideboard is to assess possible material fatigue – have you considered that?
This is a really important question because older Hemnes models can develop drying cracks over time or the wood may become more brittle.
Additional notes:
- If you mainly notice moisture damage, the affected area should be thoroughly dried and, if possible, drained.
- Minor paint and veneer damage can be effectively repaired with repair kits; for larger damage, sanding and repainting can help, provided you have a dust-free workspace and matching paint.
- For a warped drawer runner: proceed carefully, as bending it back too forcefully can quickly cause fatigue and breakage.
- For replacement parts, if Ikea no longer supplies them, I recommend looking for compatible drawer slides at hardware stores or specialist suppliers – they can often be adapted.
If you like, I can also prepare a short checklist for home repairs.
One more note: if the piece is especially important to you, it may be worth occasionally discussing professional restoration, at least for the visually prominent areas.
