ᐅ How can Malm furniture be protected from stains?
Created on: 3 Sep 2024 14:23
ankeo6
ankeo6
3 Sep 2024 14:23
Hello everyone, I recently purchased some Malm furniture from Ikea, mainly dressers and nightstands from the series that usually have a melamine coating. I’m now concerned about stains from water, coffee, or other liquids damaging the surface. My goal is to keep this furniture durable and looking good without unsightly rings or discoloration.
My specific question is: How can Malm furniture be protected against stains and permanent damage? What measures are recommended, and are there any particular care products or protective treatments you can recommend based on your experience? I’m especially interested in a method that does not damage the finish or surface but provides effective moisture protection.
I would appreciate any tips on regular cleaning, handling potential contaminants, and preventive care!
ju_ren
3 Sep 2024 14:37
It is best to use coasters for glasses and cups to prevent moisture from coming into direct contact with the surface. Stains should be wiped off quickly with a damp, soft cloth.
Additionally, clear plastic or glass sheets can be placed on the furniture if it is frequently used.
Fitigu
3 Sep 2024 17:02
The protection of Malm furniture against stains and moisture primarily depends on preserving the surface coating. This coating is usually made of melamine resin, which generally provides some resistance to liquids but is not completely waterproof.
A very effective method is the use of removable protective films or sheets made of transparent plastic foil, specially designed for furniture. These create a physical barrier and prevent moisture or oil from penetrating.
Additionally, it is advisable to avoid aggressive cleaners, as they can damage the surface. Mild soap solutions or special furniture cleaners for melamine-coated surfaces are suitable for cleaning.
Regular maintenance with a slightly damp microfiber cloth removes dust and prevents dirt from settling.
It is especially important to remove liquids immediately and not to expose the furniture to direct moisture. A protective wax layer is not necessary for melamine furniture and, if inappropriate, can even cause damage.
Dilen
4 Sep 2024 09:51
Hello ankeo6, your question is very well thought out, and I’m happy to explain in detail how you can best protect your Malm furniture.
First of all, it is important to understand that while the melamine coating on Malm furniture is resistant to everyday stains, it is not resistant to harsh chemicals or excessive moisture. The surface has some water repellency, but standing liquids or dried stains can damage the surface or at least leave unsightly marks.
A practical approach is to systematically protect the furniture with coasters or small trays under vases, glasses, and teacups. This way, no liquid stays directly on the surface.
In addition, I recommend a transparent protective film made of polyethylene or polyvinyl chloride (PVC) that you can cut to size. This film is almost invisible, waterproof, and prevents mechanical damage. The film should be designed specifically for smooth surfaces to minimize bubbling.
When cleaning, it is important not to use abrasive sponges or aggressive cleaners. A microfiber cloth with lukewarm water is usually sufficient. For stubborn stains, you can use a few drops of mild dish soap, but then rinse thoroughly with water and dry immediately.
One more tip: In particularly humid rooms (bathroom, kitchen), it is worth using a dehumidifier or at least occasionally moving the furniture to a drier location, as moisture can accumulate over time between the film and the furniture, potentially damaging the melamine coating.
If you like, I can provide some examples of transparent protective films that have proven effective in practical tests. Just let me know if you want that!
