ᐅ How can you prevent IKEA Brimnes furniture from wobbling on uneven floors?
Created on: 3 Aug 2019 11:07
EdennarHello everyone,
I recently bought an IKEA Brimnes bed and noticed that it wobbles quite a bit on my uneven parquet floor. This is not only annoying but also makes the furniture feel unstable overall. I know that furniture with flat, solid feet often causes problems on uneven surfaces.
My specific question is: How can you effectively prevent IKEA Brimnes furniture—especially beds, wardrobes, or dressers from this series—from wobbling on an uneven floor?
I’m looking for practical solutions that provide not only short-term relief but also long-term stability. Are there proven techniques, adjustments, or accessories that work well for this? What materials or aids would you recommend to ensure the furniture stays firmly in place over time without tipping or shifting when leaning on it?
Looking forward to your experiences and advice!
Hello Edennar,
Your question about stabilizing IKEA Brimnes furniture on uneven floors is completely valid. The Brimnes series often features flat metal legs that offer little flexibility—especially on bumpy or irregular surfaces.
Here are a few tips I usually recommend:
- First, check whether the legs are fully touching the floor. If not, you can use small rubber or felt furniture pads to help even out the contact.
- For larger unevenness, adjustable-height furniture legs can be installed in place of the original ones. These can be adjusted precisely, down to the millimeter.
- A simple and cost-effective alternative is self-adhesive felt or carpet gliders that you stick to the bottom of the legs. They also help reduce noise.
- Another option is inserting thin wooden shims or sturdy cardboard strips under individual legs until the furniture stands level. Precise measuring is important here.
- It’s also essential that the furniture is properly assembled and aligned. Sometimes wobbling occurs because screws have slightly loosened.
If you can provide more details about the type of floor (wood, tiles, carpet), I can offer more specific recommendations.
Hope this helps!
Hope this helps!
V
valerie-tr4 Aug 2019 09:16Hello everyone,
I would like to go into more detail on this topic because I have personally had some experience with IKEA Brimnes furniture on uneven floors.
The main reason why furniture like the Brimnes series wobbles on uneven floors is that they usually do not have adjustable feet. The metal feet are flat, mostly rigid, and cannot adapt to floor irregularities.
My suggested solution involves several steps:
- Step 1: Analyze the floor
Identify exactly where the uneven spots are, for example using a spirit level or a small ruler. If the unevenness is widespread, consider using an underlay.
- Step 2: Use appropriate leveling materials
For minor unevenness, felt pads or furniture stoppers are suitable. For larger irregularities, I recommend adjustable furniture feet from a hardware store that can be installed instead of the original feet. With the Brimnes series, you may need to replace the metal feet or add supports underneath.
- Step 3: Improve fastening
Since Brimnes furniture is mainly assembled with slot connections and screws, these joints should be checked and tightened. Adding corner brackets inside the furniture can also provide extra stability.
- Step 4: Consider alternative floor constructions
In some cases, it is worth placing a stable, thin wooden board as a base on the floor – this creates a completely level support surface and distributes the weight better. This is particularly helpful if you have uneven parquet or wooden floorboards.
For practical implementation, it is important to first examine the exact condition of the floor and then choose the appropriate solution accordingly.
One more question for Edennar: How uneven is your floor? Are the height differences small (1-2 mm (0.04-0.08 inches)) or noticeably larger? This information helps to find the most suitable solution.
In summary: A combination of leveling materials (felt, hard rubber), possibly adjustable feet, and secure assembly will ensure long-term stability for Brimnes furniture on uneven floors.
valerie-tr schrieb:
The main reason why furniture like the Brimnes series wobbles on uneven floors is that they usually don’t have adjustable feet.I agree with this. Additionally, I would like to summarize three practical and reliable approaches:
- Using furniture glides of different thicknesses for fine adjustment
- Replacing the feet with height-adjustable versions (e.g., from industrial supply stores or home improvement centers)
- Inserting leveling plates or a thin wooden board as a stable base
Furthermore, I recommend assembling the furniture on the flattest possible surface and only moving it to its designated place afterward. This helps minimize setup errors that could increase wobbling.
If the floor is significantly uneven, temporary measures are usually ineffective. In such cases, it is better to invest in a stable and adjustable substructure.
Please ensure that the materials used do not absorb moisture and have non-slip properties to guarantee lasting stability.
Edennar schrieb:
How can you effectively prevent IKEA Brimnes furniture – especially beds, wardrobes, or dressers from the series – from wobbling on an uneven floor?Good morning,
to answer your question in detail, here is a short guide that I have personally used several times:
1. Set up the furniture and check the contact points
Distribute the weight evenly on the four legs and see which leg or legs are not fully touching the floor.
2. Measure the height difference
Using a small ruler or tape measure, measure the gap between the floor and the bottom of the wobbling leg. Small differences of 1–3 mm (0.04–0.12 inch) can be easily compensated.
3. Prepare leveling materials
For minor height differences I recommend:
- Felt pads in several layers
- Self-adhesive rubber bumpers
- Thin plastic washers
Avoid using materials that are too soft, as these may compress over time and cause wobbling again.
4. Adjustment
You can either stick the anti-slip materials under the legs or wedge them in between if the legs have protruding edges.
5. Alternative solution for larger unevenness
If the difference is more than 5 mm (0.2 inch), a height-adjustable furniture leg solution is worthwhile. These usually have a screw for fine adjustment and provide a stable fit.
6. Check the assembly
Finally, always tighten all connecting screws, since light wobbling is often caused by elements that are not screwed in tightly enough.
In conclusion: make sure the materials you use do not damage the floor, especially with hardwood flooring. Felt is ideal for this.
Good luck with your project!
