ᐅ How can you make the drawers on the Malm bedside table quieter?
Created on: 4 Jun 2024 19:17
franca3
I have a question that might be familiar to many IKEA owners with the Malm nightstand: How can you make the drawers of the Malm nightstand quieter? The drawers don’t stick, but when opening and closing, there is definitely some noticeable squeaking or scraping, which can be especially disturbing at night. I suspect this is due to the suspension or the drawer slides, but I’m not sure how to fix it permanently and effectively without compromising the appearance or function. Does anyone know good tricks or proven solutions to make the drawers run more quietly? I look forward to your tips and experiences!
flo-Theres
5 Jun 2024 11:52
Regarding silicone spray: Most commercially available sprays for household or automotive use are suitable for indoor areas but often have a noticeable odor that can last for several hours after application. It is important to ventilate well and continue using the room while it dries.
If you are looking for an odorless alternative, graphite powder is also an option. It produces no smell and has good lubricating and friction-reducing properties. However, it is somewhat more difficult to apply since it is a dry powder.
Re-lubrication is normal for most sliding rails, as lubricants wear off over time or dirt accumulates.
Wesley
5 Jun 2024 14:27
A quick tip with a wink: If the noise level really keeps you awake, you could always consider saying goodbye to the bedside table—but hey, we don’t really want that, right? 😉
But seriously – I simply attached transparent felt pads to the sides of my Malm drawers (where they touch the inside walls). No more nighttime drama, the pads significantly reduce the noise!
You don’t always have to turn to technology. Sometimes small dampers can make a huge difference.
Lorukeo
5 Jun 2024 17:03
Summary of Best Practices:
- Clean the guide rails: remove dust and hair immediately.
- Use silicone spray or PTFE spray for lasting lubrication.
- Check screws and adjust as needed.
- Install felt or foam rubber pads at contact points to reduce noise.
It is also often recommended to inspect the rollers (if present) and replace them if necessary, as wear can cause increased noise. In some cases, brand-specific replacement parts can be obtained from IKEA.
All measures should be performed with attention to functionality to avoid compromising stability.
Nabla64
6 Jun 2024 07:44
As an additional routine check that is often overlooked: If the bedside table stands on an uneven floor, it can affect the stability of the drawers, which may cause noises. Simply adjust the feet or place small felt pads or supports underneath.
Also, the drawer box should not be overloaded to avoid stressing the runners and potential warping.
In summary: cleaning + lubrication + cushioning + stability check = optimal solution.
TEOZAR
6 Jun 2024 10:12
Thank you for the helpful contributions so far! I would like to briefly explain the basics of why drawers make noise:
The drawer slides are usually made of metal and plastic. Dry or dirty sliding elements increase friction, which leads to rolling or creaking sounds. Lubrication with suitable products (silicone/PTFE) reduces friction and noise.
It is also important not to open or close the drawers too quickly, as strong force increases the noise.
If you are unsure about using spray lubricants, always read the instructions and work in a well-ventilated area.
nojaus
6 Jun 2024 12:33
franca3 schrieb:
Could you tell me if silicone spray can be used indoors without smelling or releasing toxic fumes?
I completely understand why you’re cautious. I would be careful as well. If you want to be absolutely sure, look for a spray that is specifically labeled for indoor use or use solid damping materials—such as felt strips or foam rubber.
Sometimes a combination works best: first reduce friction with felt, and if that’s not enough, carefully apply mild lubricants.
