ᐅ How can Malm drawers be made to slide more smoothly?
Created on: 30 Aug 2016 08:12
doto70
doto70
30 Aug 2016 08:12
Hello everyone, I have been experiencing an issue for some time now where the drawers of my Malm dresser no longer slide as smoothly as they did at first. They feel somewhat stiff, and it requires noticeably more effort to open and close them compared to before. I have already pulled out the drawers and roughly cleaned the slides, but the result was only moderate. My specific question is: What options are there to make Malm drawers slide more easily without having to replace the entire slide mechanism? Are there any special lubricants or tricks you would recommend? I want to avoid the drawers squeaking or getting dirty in the future. Thanks in advance for your tips!
labau
30 Aug 2016 09:45
So far, silicone spray or special furniture oil often helps with Malm drawers. First, clean thoroughly, then spray lightly, not too much. Avoid petroleum jelly, as it attracts dust.
BARSAN
30 Aug 2016 10:32
After cleaning, you could lubricate with graphite powder. It is dry, does not attract dirt, and reduces friction very effectively.
blaix
30 Aug 2016 14:17
labau schrieb:
Avoid petroleum jelly, it attracts dust.
I consider that an important point. But could a misalignment of the drawer slide also cause it to operate stiffly? Lubricants alone cannot compensate for a mechanical issue in the long run. Perhaps there is uneven load or contamination? I would recommend thoroughly inspecting the rails before lubricating and, if necessary, making slight adjustments.
doto70
31 Aug 2016 07:48
blaix schrieb:
I would recommend thoroughly checking the rails before lubricating and, if necessary, making slight adjustments.
Thanks for the tip! I will take a closer look at the rails. But how can I adjust the slides on the Malm drawers? Is there any instruction for that? In my case, it seems more like the runners are sticking due to dust and small lint.
Garth49
31 Aug 2016 08:21
That’s brilliant if you properly clean and lubricate the tracks! 🙂 I had the same issue with my Malm dresser. I completely removed the drawer slides, cleaned them with a cloth and some dish soap, then dried them thoroughly. After that, I applied some silicone spray – now the drawers slide like a dream! No more awkwardness! Give it a try; you’ll be amazed!
