ᐅ How can you easily paint and protect Ikea Hemnes furniture?
Created on: 26 Mar 2020 09:34
Fovin46
Fovin46
26 Mar 2020 09:34
Hello everyone, I have a somewhat specific question about the surface treatment of my Ikea Hemnes furniture series. I want to simply varnish the wood surfaces to preserve the classic design, but at the same time, the coating should provide durable protection against everyday wear, moisture, and light scratches.
Since Hemnes is made of pine wood, I’m wondering how best to prepare the surface, which varnish to ideally use, and whether sealing or an additional protective layer makes sense to ensure both appearance and longevity.
Does anyone have experience with a practical and straightforward approach? Tips on preparation, product selection, and application details would be very helpful.
GUSTAVO56
26 Mar 2020 10:12
Hello Fovin46,
your question about a simple yet effective method to paint and protect Hemnes furniture hits the mark. I have painted pine wood several times, and here are my detailed tips:
- Preparation: First, thoroughly sand the surface. Start with 120 grit, then follow up with 180 grit to achieve a smooth finish. Pay special attention to removing all existing surface treatments (wax, oils, or paint residues).
- Primer: A high-quality wood primer, ideally acrylic-based, ensures better adhesion of the topcoat and prevents stains from the wood bleeding through.
- Paint choice: For Hemnes furniture, I recommend a water-based polyurethane finish, as it dries quickly, has low odor, and provides durability against mechanical wear and moisture.
- Application: Apply the paint with a high-quality brush or foam roller. Multiple thin coats are better than one thick coat. Lightly sand between coats with 240 grit to improve the adhesion of the next layer.
- Protection: A final clear coat with a polyurethane base gives optimal resistance to scratches and moisture.
One more question: How do you plan to use the furniture? In the living area or workspace? This can slightly influence the choice of paints.
I hope this helps you get started!
Forrest
26 Mar 2020 12:07
GUSTAVO56 schrieb:
Apply the paint with a high-quality brush or foam roller. Several thin coats are better than one thick one.
Exactly! Thick paint not only looks unattractive but can also cause unsightly runs. It’s also worth working carefully and sanding lightly between coats for a really smooth, polished finish.
And hey, if you don’t get it 100% perfect despite using protection, don’t worry: wood is a natural material, and small imperfections can actually add character.
One more tip: be sure to spray or wipe down the surface beforehand to remove dust. Nothing is more annoying than particles trapped in the paint!
If you prefer a natural wood look, you can also try semi-transparent stains, which protect the wood while highlighting the grain.
Enjoy painting—it will look great!
Chendu
26 Mar 2020 17:49
Lightly sand the wood, then apply two coats of acrylic paint, followed by a clear coat for protection. Nothing complicated, and it holds up well.
V
vinli
27 Mar 2020 08:03
Fovin46 schrieb:
I want to simply paint the wooden surfaces to preserve the classic design, but at the same time, the paint should provide durable protection against everyday wear, moisture, and minor scratches.
Applying a protective paint layer can generally be done in several steps: start with good sandpaper (180 to 220), then a suitable acrylic primer, followed by several coats of paint. A water-based polyurethane paint with a matte finish is recommended, as it preserves the original design while ensuring protection.
An additional clear coat with paste wax offers only limited extra protection and increases maintenance efforts.
As an eco-friendly alternative, a hard wax oil can be used, which is easy to renew but less resistant to water.
Ultimately, multiple thin coats of paint combined with careful sanding between layers are key to achieving a smooth, durable surface.
