ᐅ How can you customize Ikea Pax wardrobes by applying adhesive films?
Created on: 27 May 2021 18:37
san44
san44
27 May 2021 18:37
I am considering customizing my Ikea Pax wardrobe to make it more visually appealing by applying adhesive films to the fronts. My main goal is to achieve a professional and durable finish that can look both simple and distinctive. I am especially interested in tips for properly preparing the surfaces, the best types of film to use, how to avoid air bubbles, and whether there are special tools that can make the process easier. Has anyone had experience with different types of films (e.g., self-adhesive vinyl films, HPL films, or others) on the Pax system? I would also be curious to hear about any unique design ideas or techniques that are practical to implement.
Thanks in advance for your ideas and advice!
fepau
27 May 2021 20:02
san44 schrieb:
I am particularly interested in tips for proper surface preparation, which type of film is best to use, how to avoid air bubbles, and whether there are special tools that make the work easier.
Hey, this topic is really exciting! A few months ago, I covered my Pax with self-adhesive vinyl film. My tip: thoroughly clean the surface beforehand and degrease it with isopropyl alcohol so the film sticks firmly. In terms of tools, a squeegee or a special vinyl squeegee helps to apply the film smoothly and push out air bubbles.
If a bubble appears, you can often pierce it gently with a small needle and carefully smooth it out. So don’t panic right away! I really enjoy working with the film because you can try so many designs and it completely changes the feel of the wardrobe. So: be brave and give it a try! 🙂
PRA64
28 May 2021 09:46
to respond in more detail to san44’s question and fepau’s suggestions, here is a brief guide on applying adhesive films to Ikea Pax fronts:
- Preparation: It is essential to make the surface completely free of dust and grease. Isopropyl alcohol or a specialized plastic cleaner is suitable for this purpose.
- Film type: Self-adhesive vinyl films are best suited because they are flexible, easy to cut, and provide strong adhesion. HPL (high-pressure laminate) films are more commonly used as countertop coverings and are more difficult to apply yourself since they often need to be glued and pressed.
- Tools: A plastic squeegee, a sharp utility knife, and optionally a hairdryer or heat gun are helpful when working around curves or edges, as heat makes the adhesive film more pliable.
- Application: Start at one corner, gradually peel off the backing paper, and smooth the film with the squeegee.
- Removing bubbles: Small air bubbles can be released by carefully puncturing them with a needle or utility knife. For larger bubbles, lift the film slightly before final adhesion and reposition as needed.
Additionally, I recommend paying attention to the surface texture when choosing the film: matte, glossy, or textured—depending on your interior style.
Conclusion: The combination of thorough preparation, suitable materials, and the right tools makes all the difference!
Layla
29 May 2021 11:17
PRA64 schrieb:
Conclusion: The combination of careful preparation, suitable materials, and the right tools makes all the difference!
I can only agree with that! I recently wrapped my own Pax, and although I was quite uncertain at first, with patience it worked out well.
Patience is especially important, because I had major issues with bubbles, as I initially thought you should apply the wrap quickly. I then learned to smooth the wrap gradually and to gently adjust it in a wave-like motion in between – this helped relieve the pressure.
Additionally, I chose a textured wrap because I was worried about visible scratches. This proved effective, as minimal imperfections or dust are much less noticeable.
For those who feel unsure: a small tip from me – practice first on a small panel or an unimportant area before applying the wrap to main surfaces. This way, you gain experience and any mistakes are less noticeable.
