ᐅ How can you modify Ikea Besta units to achieve a slim and streamlined appearance?
Created on: 29 Oct 2016 08:17
Fargau
Fargau
29 Oct 2016 08:17
I recently bought an Ikea Besta system and generally find the dimensions and modular structure very practical. However, the entire piece of furniture looks somewhat bulky and heavy in my rather slim living space. My question is: How can the Ikea Besta be modified or customized for a more streamlined appearance? I am thinking of adjustments such as narrower fronts, reduced depths, selective high-gloss or color accents, possibly removable or slimmer frames—in short, solutions that make the furniture look less massive without completely sacrificing stability or storage capacity. Does anyone have experience or clever remodeling ideas that achieve this effect? I am open to even more unusual suggestions that make the Besta system appear more delicate and modern.
anlu67
29 Oct 2016 09:02
The easiest way is to replace the doors with smooth, white fronts without handles. Adding feet under the cabinets also makes the furniture appear lighter. Reduce the depth by trimming the back panels – but only if the stability is maintained.
libar49
29 Oct 2016 09:45
Fargau schrieb:
How can Ikea Besta be modified or rebuilt for a slimmer look?
I find this question quite in need of explanation – why does everyone want to make the Ikea design "slimmer"? Isn’t that a rejection of the designers’ intent? The Besta system is defined by its clarity and simple modularity, and it definitely has presence. If you confuse it with delicate furniture, you miss the point. My advice: instead of modifying it, consciously opt for minimal decoration and avoid half-hearted alterations.
harold
29 Oct 2016 10:31
Good morning everyone,
Regarding the topic "Slimming down Ikea Besta," I would like to share a brief guide:
- First: Choose high-gloss fronts if possible; they reflect light and appear less bulky.
- Option: Use narrow plinth feet to raise the furniture off the floor. This visually reduces its weight.
- You can round off the frame and visible edges with fine sandpaper, creating a light and modern look.
- If needed, reduce the depth gently: Although Ikea rarely designs for this, you can carefully cut the back panel.
- Use wall mounting to pull the cabinets slightly away from the wall, which makes them look less heavy.
Make sure all modifications remain stable and do not damage any load-bearing structures. Mistakes here can quickly cause the units to become wobbly.
Good luck with your renovation!
WARREN
29 Oct 2016 11:07
I have remodeled my Besta by completely removing the doors and installing fabric curtains instead. This creates a more open and less bulky appearance. It also allows for flexible design options and the introduction of colors.
tolokau
29 Oct 2016 12:53
Hello Fargau,
I would like to recommend a systematic approach:
1. Planning: Measure your room precisely and identify which dimensions are the most critical.
2. Module selection: Choose shallower and narrower Besta units, which are available in different depths (e.g., 20 cm (8 inches) instead of 40 cm (16 inches)).
3. Replace fronts: Use slim or frameless doors, for example, made of glass or thin MDF.
4. Add legs: Tall, slender legs create a sense of lightness.
5. Color: Light colors visually expand the space, while dark colors make it feel heavier.
Avoid mistakes: Do not screw or cut into load-bearing side edges. The stability of Besta depends heavily on its integral structure.
In summary: You can achieve a slim look by combining smaller depths, more delicate fronts, lighter color choices, and elevating furniture with legs.
