ᐅ How can the surface of Ikea Platsa be protected after repainting?
Created on: 23 Jun 2024 09:12
MAMISLAV
MAMISLAV
23 Jun 2024 09:12
Hello everyone, I am planning to repaint my Ikea Platsa cabinet to give it a custom look. However, I am concerned about the durability and protection of the painted surface. My question is: What is the best way to protect the freshly painted surface of Ikea Platsa furniture from mechanical damage, scratches, and general wear, so that the new finish stays looking good for a long time? I would like to know which sealants, types of paint, or additional coating steps have proven effective, and if anyone has experience with specific sealants for MDF or particleboard, as used in Platsa. Thanks in advance for your tips and advice!
Domau0
23 Jun 2024 09:45
Hello MAMISLAV,
If you are painting an Ikea Platsa cabinet, you should first know that the surface is usually melamine-coated or laminated, which can make it difficult for paint to adhere properly. A crucial initial step is to thoroughly sand the surface with fine-grit sandpaper (e.g., grit 220 to 320) to ensure the paint sticks well.
After that, I strongly recommend applying a primer to prevent unevenness and potential paint problems. For sealing after painting, there are several options:
- Clear coats based on acrylic or polyurethane, which are very resistant to scratches and impacts
- Hardwax oil, which creates a natural finish but offers somewhat less protection
- Furniture sealants with polyurethane or polyacrylic, specifically designed for MDF or particleboard
Your choice also depends on whether you want a matte, satin, or glossy finish.
One more tip: Paint layers should be thin and fully dried; otherwise, the surface can crack easily. After applying the sealant, it’s advisable to let it cure in a dust-free area for at least 48 hours.
It would also be helpful to know exactly which type of paint you are using to give more targeted advice. Have you already chosen a paint brand or type?
te-min
23 Jun 2024 10:03
It is best to sand the surface thoroughly, then apply a high-quality primer. For the final coat, use a clear polyurethane finish, which provides good protection against scratches and moisture.
Nathanaelk
23 Jun 2024 11:27
Hello, I would like to go into more detail on this topic: Ikea Platsa is mostly made of particleboard with a foil or melamine coating — which means the surface is very smooth and not very paint-absorbent. If you plan to paint such a surface, I recommend thorough preparation:
- You should definitely treat the surface with a primer, ideally an acrylic-based one designed specifically for hard-to-paint surfaces.
- Then apply thin paint layers by spraying or using a high-quality specialty brush. Each layer should be allowed to dry completely.
- For protection, a two-component polyurethane (2K PU) clear coat is recommended, which forms a particularly hard, scratch-resistant, and chemically resistant surface after full curing.
I also suggest testing on an inconspicuous area before painting large surfaces. Another point to consider: if the Platsa cabinet is exposed to moisture (e.g., in a bathroom or kitchen), a polyurethane sealant is much better suited than a simple acrylic sealant due to its water resistance.
I am also curious: In which room will the cabinet be placed? How strong should the protection be (normal wear or rather heavy use)?
MAMISLAV
23 Jun 2024 12:15
Domau0 schrieb:
It would also be important to know exactly which paint you are using in order to provide more targeted advice. Have you already chosen a paint brand or type?
Thanks for the suggestion. I plan to use a water-based acrylic paint because I prefer the most environmentally friendly option possible. Clear coats with PU content sound interesting, but I’m unsure whether they might significantly change the color tone or make the surface too glossy. Regarding the room: the cabinet is in the living room, so it will face normal wear and tear, with no direct moisture exposure. However, the surface should still be durable against scratches and dust. Do you have any recommendations on whether a two-component PU varnish or a matte acrylic clear coat would be better?
GALEO4
23 Jun 2024 13:03
MAMISLAV schrieb:
Clear coat with a PU component sounds interesting, although I’m unsure if it might significantly change the color tone or make the surface too glossy.
That’s exactly the point. PU varnish is often marketed as super protective, but in reality, it can strongly alter the character of the color because it creates a hard, almost plastic-like surface. My advice: don’t be dazzled by supposed high-tech coatings. If you want a beautiful, natural look, pay attention to matte or satin finishes. They may be a bit less durable, but they are more authentic.
PS: Did you know that many furniture manufacturers deliberately use only matte sealants to keep the surfaces looking as refined and natural as possible, rather than artificial?
