I would like to know the best way to renovate the surface of IKEA Billy shelves without completely replacing the unit. The goal is to refresh or improve the typical laminate or melamine finish, for example by addressing scratches, discoloration, or minor damage. What methods are suitable for this? Should you sand and apply new paint, or is it better to use a new coating with film or special paint? Are there proven materials or techniques to achieve a smooth, durable surface? I look forward to your experiences and tips!
Basically, the surface renovation of BILLY shelves largely depends on the type of coating. Most BILLY shelves are coated with melamine resin, which is relatively durable but not designed to be repainted.
A common method for minor scratches is to touch them up with color-matched wax sticks or repair kits made for melamine-coated furniture. For complete surface renovation, applying a self-adhesive furniture foil or a special furniture film is usually recommended. Sanding and painting can be problematic because melamine does not absorb paint like wood.
If the shelf is heavily damaged, stripping the coating and applying a primer layer with an adhesion promoter might be necessary before applying a suitable paint. However, this process is more labor-intensive and not always effective.
I would like to take a more detailed look at the technical aspects here.
BILLY shelves are typically made of particleboard with a melamine resin surface. This surface is chemically very resistant and smooth, which makes mechanical treatment difficult: sanding removes only a little of the melamine without reaching the wood beneath, as there is a hard protective layer.
If you want to renovate the surface, I recommend the following steps:
1. Cleaning: Thoroughly clean with a mild detergent or isopropanol to remove dust, grease, and residues.
2. Repairing small damages: For scratches or small holes, repair kits from specialized retailers (wax, resin) are suitable.
3. Improving adhesion: If you want to paint, it is important to very lightly roughen the surface with 320 grit sandpaper (just roughen, do not sand through). Then be sure to use a special primer designed for smooth surfaces.
4. Painting: Use an acrylic or polyurethane paint specifically formulated for plastics or coated surfaces. Apply several thin layers.
5. Alternative: A high-quality self-adhesive film (e.g., PVC or vinyl) can also be applied to the cleaned surface. Make sure to avoid bubbles during application.
My question would be: What is the level of wear and what color or pattern preferences are there? This will influence the choice of method.
Wow, that sounds quite elaborate! I treated my BILLY shelves with spray-on coating (Plasti Dip) and the result is fantastic! 🙂 The surface even feels slightly rubbery and is resistant to scratches and water. Of course, the preparation with cleaning and sanding was a bit time-consuming – but the result is definitely worth it! If anyone wants to spray: work in a well-ventilated area and apply several thin layers. It’s really fun, give it a try!
pikin schrieb:
Sanding and painting is challenging because melamine does not absorb like wood.That is correct, but I wonder if sanding between coats and using a special primer could achieve a durable, reliable paint finish. Does anyone have solid experimental data or practical experience regarding the durability of paint on melamine in household use? I have the impression that many recommendations are based more on assumptions and practical trials with contact paper or spray film, rather than on systematically refurbishing with paint.
