Hello everyone, I have a question and would appreciate your experience and advice. How can the lifespan of Malm dressers be extended? Specifically, Iâm interested in preventative measures to avoid common wear issues such as edge chipping, drawer misalignment, and maintaining stability over the years. Do you have any special care tips, recommended products, or modifications/reinforcements? Are there any material-specific considerations to keep in mind? Iâve been using my dresser for about five years now and have noticed that its durability is decreasing in some areas. Thanks in advance for your help!
Hello Kulopau, thatâs a very good question! The Malm dressers are known for their simple design, but when it comes to durability, there are a few important points to consider. First of all: The materials used in the Malm series mainly consist of particleboard with a thin paint or laminate coating. These are not as robust as solid wood, so the key lies in careful handling and prevention.
1. Avoid moisture: Moisture causes particleboard to swell and can weaken the glue joints. Therefore, make sure the dresser is not placed in damp rooms or exposed to spilled liquids.
2. Tighten screws: Over time, connections can loosen. It is recommended to tighten all screws and fasteners every 6 to 12 months to prevent drawers from sagging or rattling noises from occurring.
3. Protect edges: The edges are particularly prone to chipping. Transparent edge protectors made of rubber or plastic can help here. These are often available online and are easy to apply.
4. Check drawer slides: The guide rails should be regularly inspected and lightly lubricated to avoid stiff or sticking operation.
It would be helpful to know exactly where you use the dresser (childrenâs room, bedroom?) and if there are any special stresses in that area. I also wonder if you have already carried out any minor repairs or if this is more about preventive care. That way I can give you more specific advice.
Hello Kulopau, Iâd like to respond to your question and offer some practical tips to extend the lifespan of your Malm dresser.
First of all: The biggest threat to the Malm dresser is actually the combination of heavy load and moisture.
1. Assembly quality: Often, this is where savings are made or the instructions are followed somewhat hastily. A firmly and properly screwed-together carcass prevents later deformities. Pay special attention to ensure all wooden dowels fit correctly and screws are not over-tightened.
2. Use and load: Avoid heavy loads in the upper drawers. The lower levels are more stable. Also, evenly distributing the load in the drawers reduces stress on the runners.
3. Maintenance: Keep dust and moisture away. A soft, slightly damp cloth is ideal â never wipe with a soaking wet cloth!
4. Repairs: If edges are damaged, you can use special furniture repair markers or wood filler. It is important to sand and clean the damaged areas before applying anything.
5. Upgrades: Sometimes it helps to reinforce the back panel with extra braces or to support the drawer bottoms with thin plywood sheets if they start to sag.
I hope this helps you for now! If you like, I can also provide examples of materials or sources.
PIN66 schrieb:That should always be kept in mind. Iâll organize my tips as follows:
The materials of the Malm series mainly consist of particleboard with a thin lacquer or foil coating.
Wow, this is such an exciting topic! 🙂 I really love my Malm dresser, but some of the finish has already started to peel off. However, Iâve tried a few tips that have really helped!
First: adhesive films! There are great self-adhesive films that you can easily apply to the dresser surfaces. Not only do they make the furniture look fresher, but the film also protects against scratches and moisture.
Second: finish care! Once a year, I use a special furniture polish varnish (available, for example, at hardware stores), which you apply very thinly with a soft cloth. This keeps the surface smooth and protects the edges best.
Third: drawers with felt pad liners! When thereâs something heavy inside, the drawers donât rest directly on the runners and therefore squeak less. This is super easy to retrofit!
You just have to stay consistent, and this really makes the dresser last longer. Iâm looking forward to more ideas! Itâs great when you can use furniture for as long as possible! 🙂
