I recently bought some Ikea Platsa cabinets, which I like visually, but the surface of the white fronts is already somewhat worn with minor scratches and discoloration. In the long term, I would like to renovate or at least improve the appearance of the surface without having to replace everything completely.
So my question to you is: What is the best way to renovate the surface of Ikea Platsa furniture?
- Are there suitable materials for refurbishing the fronts yourself?
- Does sanding and painting help, or could that possibly affect the fit or appearance?
- Or are special films/wrapping tape solutions advisable?
I would also appreciate tips on properly preparing the surface and any potential pitfalls to watch out for.
Looking forward to your opinions and experiences!
Karsten4530 Oct 2021 09:26Hello potra,
I really like your question, especially since PLATSA is so flexible, you don’t want to just throw away the front panels if they have small scratches. 😊
In short: yes, sanding and painting is an option, but it requires patience – the surface is often melamine-coated, which needs to be painted. It’s best to use very fine sandpaper (grit 400+) to roughen the surface, then apply a primer, followed by several thin layers of paint.
Alternatively, I like to use self-adhesive films – available in many colors and patterns. They stick well if the surface is clean and smooth, and you can easily customize the entire piece of furniture this way. Just make sure the edges stick properly, or they might peel off due to temperature changes.
Oh, and before painting or applying film, I recommend thoroughly degreasing the surface. A tip from me: use rubbing alcohol or a mild cleaner.
Good luck with your renovation!
Hello potra,
I’d like to respond to your question in more detail, as I personally tried to refresh PLATSA fronts a few months ago.
The surface of PLATSA furniture is usually melamine-coated, which makes it fairly durable but also less suitable for sanding compared to solid wood surfaces. Sanding too aggressively can quickly cause unsightly scratches on the surface.
Here’s my recommendation:
- Cleaning: First, clean and degrease the fronts using a mild cleaner (isopropanol works well).
- Small scratches can be concealed with a special furniture repair pen.
- For renovating larger areas, I suggest using very fine sandpaper (e.g., 600 grit) to only lightly scuff the surface.
- Then apply a high-quality primer suited for melamine surfaces (such as spray primer).
- After that, apply several thin coats of acrylic paint in the desired color to restore shine.
If you prefer not to paint, films or even custom-cut adhesive vinyl are a quick and cost-effective alternative. These can also be removed later if you no longer like the new design.
One more tip: Depending on how much you sand and which materials you use, the surface might become slightly roughened or dull. So it’s best to test on an inconspicuous spot first.
I hope this helps you!
Hi everyone!
I can only agree with AMELIE – such a renovation is really fun and gives the PLATSA furniture a completely new look! Recently, I refreshed my white fronts with a bit more color courage – and it was definitely worth it! 😀
What really helped me:
- Thoroughly clean the surface (no dust, grease, or dirt left)
- Lightly sand with 600 grit or finer
- Use a primer, otherwise the paint won’t adhere properly
- Then spray acrylic paint in several thin layers, don’t apply too thickly!
And please be patient – let it dry well between coats!
The advantage of spray paint over a brush is that the surface becomes super smooth. If you’re up for experimenting, try adding color accents; it looks really fresh!
So go ahead, it’s a lot of fun and your PLATSA will look almost like new! 💪
AMELIE schrieb:
For renovating larger areas, I recommend using very fine sandpaper (e.g., grit 600) to slightly roughen the surface. I completely agree; precise sanding is essential here.
Additionally, I would like to add that when choosing the paint, it’s important to select one suitable for melamine-hard surfaces, otherwise the finish won’t last long. Special synthetic resin paints or two-component (2K) paints offer better protection.
Using a dedicated degreasing solution before painting (not just water or dish soap) also helps to thoroughly remove residues.
Regarding films: this solution is often simple and time-saving, but the durability depends on the quality of the film and the environmental conditions. In particular, in humid rooms, bubbles often form or edges start to lift over time.
My advice: if you want something durable in the long term, the effort of using a primer and paint is ultimately more worthwhile.
