ᐅ How can the IKEA Brimnes surface be protected after assembly?
Created on: 16 May 2019 08:45
FLOYAEL
Hello everyone, I recently assembled my new IKEA Brimnes furniture and am now wondering how to best protect the surface to keep it looking like new for as long as possible. I am especially interested in methods or products that help prevent scratches, minor wear, and general abrasion without negatively affecting the appearance or feel. Are there any home remedies or specialized care products you would recommend? I would also like to know if sealing with a specific type of varnish or wax is advisable and how these should be applied. I look forward to your experiences and tips!
CORYGAU
16 May 2019 15:10
RonJarrett schrieb:
An additional protective film is possible but usually not preferred for aesthetic reasons.
This is a crucial point: The benefit of a protective film often conflicts with the appearance. To preserve the original design, it is better to rely on behavioral measures such as regular cleaning and avoiding dirty hands. This approach is more sustainable and effectively prevents damage.
pinJustin
16 May 2019 15:35
For surface maintenance, I simply use a dry microfiber cloth and, if needed, a cloth slightly dampened with water. I avoid using cleaning products to keep the surface unchanged.
Deandre
17 May 2019 08:50
Good morning! A small addition in case someone wants to specially protect heavily used areas: There are also clear water-based furniture lacquers that can be applied thinly. However, be careful, as this changes the surface and is only reliably safe with testing. Ideally, you should always try it first on a backside.
Garthre
17 May 2019 09:12
Those looking for a temporary solution can also place protective films or felt pads on the surfaces. Minor damages such as scratches can be largely prevented this way.
FLOYAEL
17 May 2019 09:45
Thank you for the many helpful tips in this thread! I will start by using soft felt pads and keep the cleaning gentle. If I notice in the future that the surface experiences heavy wear, I might take a closer look at clear furniture lacquers. I find the insight that sealants often cause more problems very important.
LAGUDO
17 May 2019 10:01
As a final note, I would like to say that you unfortunately have to accept some scratches on Brimnes, as it is not solid wood. However, with the right protective measures, it will definitely last much longer in good condition.
